1954 Bed Panel Rivets
Old Jul 3, 2012 | 09:09 PM
1954_NJ_F100's Avatar
1954_NJ_F100
I will be replacing my front bed panel.
Does anyone know what size rivets were originally used to connect the side panels to the front panel? Or have experience with using riveted bed panel connections? Thank you.
Old Jul 4, 2012 | 12:41 AM
52 Merc's Avatar
52 Merc
If you plan to re-rivet the front panel back to the bed sides, its best if you have a strong air hammer and the correct anvils to set them. It also helps a lot if you have a not-too-bright buddy (ie; one who won't run out on you holding the tool 'cause its not any fun, btdt) to hold one side. It would be much easier and plenty acceptable to simply bolt it in place.
Old Jul 4, 2012 | 07:16 AM
oldmerc's Avatar
oldmerc
oldmerc
No one who has listened to an air hammer for a half hour or so will critisize you for using bolts . Those that do should !
Old Jul 4, 2012 | 09:40 AM
1954_NJ_F100
Wayne & Allan - thanks for the advice!
I already have the bolts as my plan B. I did a little research and learned that a rivet gun looks just like an air chisel but with slower impacting and a "feather trigger." I never drove a solid rivet but thought I would give this a try.
If successful I will post my results.
66with352
May 17, 2019 06:42 PM
Itsmyford
Nov 7, 2018 12:56 PM
Smitty49
Jul 28, 2014 05:13 PM
MdubbU
Apr 14, 2014 05:19 PM
CharlieLed
Jun 30, 2011 11:05 PM
