Minnesota Chapter Join Chapter, Leader: fordpower88
Engine Perches or towers
Old 07-15-2012, 08:39 PM
78 Custom's Avatar
78 Custom
78 Custom is offline
Does anyone know where I can find a pair of Perches for a big block 460? Not sure where I can find them. Thanks
Old 07-16-2012, 06:21 AM
Ford79's Avatar
Ford79
Ford79 is offline
2 wheel drive or 4x4? What year?
Old 07-16-2012, 06:31 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Please, when asking questions, list all the pertinent info: Year, series, engine size, 2WD or 4WD and etc.
Your "About Me" profile says 1978 F150.
If you're looking for 460 4WD, you'll have to buy the engine mounting parts aftermarket. Ford didn't offer the 460 with 4WD or a M/T until 1983, and these parts will not work on anything prior to 1980.
1968/78 Passenger Car 460 & 1975/96 Econoline 460 engine mounting parts will not work on any year F100/350.
And, 1973/79 4WD's do not use perches, because there is no engine crossmember to bolt them to. The engine supports bolt to the inner frame rails.
1973/79 F100/350 460 2WD:
D3TZ-6028-A Right & D3TZ-6029-A Left .. Engine Supports aka perches, stands, towers.
D3TZ-6030-A Right & D3TZ-6031-A Left .. Brackets-These bolt to the block, the rubber insulators bolt to these, then to the supports.
2) D3TZ-6038-A .. Right/Left Rubber Insulators.
Old 07-16-2012, 03:27 PM
Devious Delight's Avatar
Devious Delight
Devious Delight is offline
I'm betting this guy can help you out...
"ALL FORD" SALVAGE YARD DOWNSIZING
Old 07-16-2012, 08:55 PM
78 Custom's Avatar
78 Custom
1978 F 150 Custom 2wd doing a swap to a 460.Has a 300 in it now. I was told I need to get different Perches.
Thanks
Ratcs250
05-01-2017 11:13 AM
Baer
WTB - Parts & other
10-22-2016 08:55 AM
choptop49ford
05-05-2016 08:42 PM
74f250USMC
06-30-2014 01:09 PM
Second79F250
04-27-2012 10:56 PM
Quick Reply: Engine Perches or towers
