Problem with leaking between transsmision and converter ! Help !
Hello,
I have problem with my Ford F-250 7,3 diesel SD from 99' XLT transmission 4r100 .
I have changed torque converter and now something leaks between transmission and this converter.
What can it be ? Any ideas ? Is there gasket which must be changed ? I didn't notic anything wrong with it.
Please help me
Please help me
I have bought new converter and just change it.
And maybe you can tell me where I can buy this seals and bushing alone because I am in Holland now and I need to order it from America. I cant find it anywhere. If you can please tell me or send me link for site where I find it.
And to change this seals and bushing do I need to take out transmission and demolished it or if I take out transmission and converter I can change it ?
You can get the parts at Transmission Parts - Transtar Industries Inc.. You don't need to tear the whole trans apart, just remove the torque converter and pump.
Do I need those two parts ?
http://www.transmissionpartsusa.com/...-000026401.htm
http://www.transmissionpartsusa.com/...-000027626.htm
Yes, you need those two parts.
You should also get this part:
E40D 4R100 transmission pump gasket E40D 4R100 transmission gaskets
You also need to remove the pan and filter, or the filter neck will break when you pry out the pump. The pan gasket should be a rubber type that is reuseable, but you might want to replace the filter with a new one, since it is common shop practice to do so, unless the filter is fairly new already.
Also, check closely the torque converter itself, sometimes you get one with a pin hole leak on the weld!
foots1
12-21-2004 10:05 AM
