1993 f150 wont idle
Old 06-29-2012, 07:27 PM
jeffmeyers351's Avatar
jeffmeyers351
jeffmeyers351 is offline
1993 f150 wont idle
at work we have a 1993 ford f150 2wd automatic, lately it hasnt been starting unless we push the gas pedal down a little bit, and as soon as you let off it dies, it wont idle at all but by keeping the gas pedal down it will stay running, the truck has a 302 with 277,699 miles on it, does anyone know what could be causing it to not idle or start, we had the fuel pump checked and it is still good.
Old 06-29-2012, 07:31 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
A few things:
Check/replace the TPS, idle air bypass, and also check the canister purge valve as well as where the vacuum lines from the valve connect to the throttle body. If those are good, I'd start looking at the fuel rail for pressure and clogged/not working injectors.
If you need more info, happy to help.
Old 06-29-2012, 07:35 PM
86cherokeek20's Avatar
86cherokeek20
86cherokeek20 is offline
i had a problem like that on my old 1977? k20, despite bein a chevy, its biggest problem was the carb base gasket blew out and it did that, so check the bolts in the upper intake
FordYoungGun35
11-12-2012 02:14 PM
carrfamilynj
12-23-2010 04:43 PM
Lafeve
1999 to 2016 Super Duty
12-10-2005 08:04 PM
92 Red F150
05-14-2004 11:00 AM
92 Red F150
05-14-2004 10:54 AM
Quick Reply: 1993 f150 wont idle
