IIRC I researched this for a guy once and found that some were made. But you'd spend a life time searching and probably come up dry. It would also seem that somebody would have made a DRW 19.5" with this 6 x 7.25" pattern, but I've found no wheel reference that lists such an animal. They were, however, made for SRW applications. If Stockton was to make these, they'd have an ugly flat center and you'd have to really watch them to be sure they factored enough offset. Then you'd also have the cost of spacers to make them DRW. Stu
Guys, I've researched the poop outta this for a guy over on the 48-56 forum. None were made, no matter the vehicle make and no matter the wheel manufacturer. It's probably wrong to tell tales on that member, but he wouldn't settle for the 17.5s that I recommended time and again, the ones Bill lists. Instead he bought a set of the Stockton custom 19.5s and hates them. Stu
