F150 Ecoboost Towing Question - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-20-2012, 05:40 PM
blueovelboy's Avatar
blueovelboy
blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
Originally Posted by rcm800 View Post
I will be under the 65' max. To be honest with you I am not real thrilled with being maxed out when towing. I worry more about the truck controlling the load than whether it has the power. But I also don't really want a 3/4 ton pickup all the time. The trips will not be real long luckily.
If I am not comfortable towing it than I will either trade to a bigger truck or maybe get a used 3/4 tom for that purpose.
Thanks for the replies all advise is helpful.
unlike the rest of the world most people don't care about what it takes to stop a load. it's all about how a truck it gets it moving. national ins safety board looks at it like this- just what can the vehicle stop safely and hold it to a safe stooping distance! and when i see people like you who have the same ideas it makes me feel good!
  #32
Old 07-21-2012, 09:52 AM
brandon4
brandon4 is online now
brandon4 is gaining momentum as a positive member of FTE.brandon4 is gaining momentum as a positive member of FTE.
Dont be afraid to turn your trailer brakes way up and slow down with your gears as much as possible. Also use "stab" braking instead of pumping or riding brakes. All this will preserve your brakes and keep them cool in case of an energency. (i.e. broken down chevys littering the highway...)
  #33
Old 08-20-2013, 11:59 AM
rcm800
rcm800 is offline
rcm800 is starting off with a positive reputation.
OK older thread with some updates. Truck still handles the camper and boat very well. Changed to some 10 ply tires and helps also. Went out to the Black Hills last week with just the camper. 7-8 mpg. On way back tranny started puking fluid and smoking. Took off belly pan and read in manual that you cannot check fluid level. Checked that it had warranty which is 5/60 and I have 42,000 miles so took off. It kept leaking all the way home but made it. Another thread says that build date from 4/?/11 to 6/?/11 these trucks had a leaking tranny issue and mine is 5/5/2011 so it is in the shop now. Will know in a soon on what needs to be done.
Question in my mind is that is this just from overloading the truck, My camper is under the advertised towing, or is it just a tranny leak. I dont want to get over the 60,000 miles and have to pay for this repair out of my pocket. Thinking about getting a diesel again now or 3/4 ton gas, not what I want.
Any opinions?
  #34
Old 08-21-2013, 09:50 AM
Mr. Mcbeevee
Mr. Mcbeevee is offline
Mr. Mcbeevee is gaining momentum as a positive member of FTE.Mr. Mcbeevee is gaining momentum as a positive member of FTE.
I do not think that you are overloaded, I think you just got a bad tranny. You can check the fluid in these. Take off the belly pan and there is a hex nut on the passenger side of the tranny. I think that it takes a 3/4 box end wrench if I rember right (do not overtighten when putting it back, it is plastic). The dipstick is attached to this nut.
  #35
Old 08-21-2013, 09:58 AM
Robbgt's Avatar
Robbgt
Robbgt is online now
Robbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to behold
Yup, what he said
Here is a link with pics: How to check transmission fluid in Ford 6R75 and 6R80 2007+ Expedition and 2009+ F150 6-speed automatic
  #36
Old 09-04-2013, 08:37 AM
rcm800
rcm800 is offline
Truck got fixed. Changed pump seal and I think converter seal. They dropped pan and all looked good. They said I only lost 3/4 quart but it seemed like more. Seems to run great now except when putting in gear I am now getting a clunk I never had. Ideas?
  #37
Old 09-05-2013, 06:38 PM
Richard Venneman
Richard Venneman is offline
Richard Venneman is starting off with a positive reputation.
My 35 foot trailer is 7800 lb dry (10,000 loaded?)and I pull it ok. 2012 FX4. My trans temp did not go above 212 on a trip down the Oregon Coast. Is anyone towing that much?
japaw
Fifth Wheel & Gooseneck RV Towing
17
10-01-2016 05:41 PM
MikeDVB
2015+ F150
65
01-22-2016 04:26 PM
center97
2009 - 2014 F150
06-28-2014 03:47 PM
skidooman
22
05-22-2014 04:11 PM
skidooman
6.2L V8
04-15-2014 03:19 PM
Quick Reply: F150 Ecoboost Towing Question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
