Short version.....Towing up mountains from Tn/NC, truck pulling best it has ever pulled, then just shutoff, never to restart. Had towed to dealer, this is what I got; Ran performance test found low ICP HP SYS building 38 PSI possible IPR stuck open.....So can anybody tell me what that means in simple form?
Missing coolant in Degas bottle...Which turned out to be the case, they was leaking not bad but still leaking.....Wasn't original issue, just trying to fix all at once, while had some spare $$$$$ and time.....
I hope yyour using ARP Head studs and OEM Headgaskets
Yes sir, going back with ARPs and OEM gaskets, water pump, oil cooler, thermostat, HPOP is there anything else I can do?.....EGR delete was done already (Sinister)
