Sponsored by: Auxito
spark plug problem.
Old Jun 26, 2012 | 01:39 PM
RodneyButrum's Avatar
RodneyButrum
spark plug problem.
I have a 97 F150 4.6L 4x4 5 speed. I ran diagnostics on it and it told me that number 3 and 8 cylinder misfired , it also said both banks were running lean and poor exhaust recirculation but i figur thats due to my exhaust being cut off from relacing the transmission but anyways i replaced both coil packs and the number 8 cylinder is fixed but cylinder three was still missing. I changed the plugs and drove for about 300 miles and pulled the plug and theres a thick black build up almost like rubber or silicone on it. Ive never encountered this before and have asked numerous people and cant get a answer. Anybody got any ideas.
Old Jun 27, 2012 | 12:21 AM
Bluegrass 7's Avatar
Bluegrass 7
Hi Rodney, You gave alot of info but ran it all togather.
First we need the codes, not your intepetation of them from your reader because they are often missunderstood.
I understand one will be a P0303.
But give the rest so none are missed.
We need to hear/see the exact EGR code because there is more than one code for EGR operational testing.
Good luck.
Old Jun 27, 2012 | 07:16 AM
RodneyButrum
The code reader only shows up 4 codes as follows.
P0171
p0174
p0404
p0303
Old Jun 27, 2012 | 12:27 PM
Bluegrass 7
Code 171/174 usually is an intake tract air leak some point after the mass air meter.
Look for deteriorated rubber fitting/ connections.
303 cylinder 3 missfire.
Recheck the boot and wire to the plug and be sure you have the fire order correct when replacing the wires.
Coil faulty.
404 is the EGR performance margin.
This code seldom comes up as a normal fault.
If you have open exhaust or some incomplete exhaust at some point, restore it to normal.
The EGR tests and operation depends on exhaust pressure to force some through the tube and into the intake through the open EGR through a port in the intake. Make sure it's all in tact and the port behind the EGR is open.
The sensor DPFE measures this performance and is the source of the code.
The DPFE could also be faulty if the rest of the hardware is in tact and open.
You should be able to clear all these faults by doing quality work and observations.
Good luck.
miniowner92
1997 - 2003 F150
Sep 7, 2018 08:51 PM
Josh Lee Ponish
1997 - 2003 F150
Jul 24, 2016 07:55 PM
weberr7
Jul 2, 2012 03:22 AM
azazel_18_2
1997 - 2003 F150
Oct 22, 2007 11:41 PM
Gunner Thomas
Feb 24, 2004 09:56 AM
