Engine Swap '99 F150
I have a '99 F150 that I picked up with a seized 5.4. I picked up a junk yard motor out of 2001 Expedition that is also a 5.4. I then found out how much fun it is to work on this thing!
So while looking into a couple issues I am having I saw a tidbit somewhere on the internet that said my motor has a timing sensor on the cam, and the new motor has the timing sensor on the crank, is this true? Can anyone shed some light on what I need to do in this situation?
The next issue is that since the motor is seized up, I cannot turn it over to disconnect the torque converter from the flexplate. Can I just pull it out with the torque converter still attached? I just am wondering how much stuff from the front end I need to remove.
Any help would be appreciated.
Tom
Tom
The one on the head is the cam position sensor. You should be able to remove the engine with the torque converter still attached but you will probably lose a lot of trans fluid. Also be careful not to get too rough so you dont damage the converter or trans shaft you may need more forward movement and clearance with torque converter attached to get the engine out. Guessing around another eight inches forward which could cause you some trouble.
Thank You for your kind reply. I don't know much about the array of sensors on modern motors. I guess the best question I can ask is this...
Is the 5.4 engine out of a 2001 Expedition compatible with the 5.4 engine in the 1999 f150? They definitely have different intake manifolds.
I removed the fan from the water pump pulley, and seem to have about 14" between the pulley and the ac condenser. Hopefully that will be enough.
Tom
Tom
Just to be safe use your current '99 harness, that will stave off any sensor problems. I don't see you having the room with the TQ on, I had the fan off, radiator out and TQ unbolted and barely had room to remove and install a 5.4L, the tight spot is when you are about 1/3 out and are at the cowl area with the back of the engine and the front still isn't above the header panel.
Take lots of pictures of everything hooked up and remember cardboard to cover the AC condenser and coolers. When you get down to it there are only half a dozen or so sensors to plug in and the length of the wire really dictates where they go.
Better to be lucky than good, huh? Funny thing is, I just dropped my fresh rebuilt 4.6 into my 98 F 150 yesterday--twice!! Had it in and mated to the tranny and then looked in my parts bin and saw the metal spacer that sits between the Engine and Bell Housing. Crap!!! didn't take too long since it was still on the cherry picker but sure did feel kinda dumb at tthe time. Enjoy your project!!
rudedogii
13
03-16-2012 01:26 PM
