86 f150 8.8 rear disc conversion
06-25-2012, 06:06 PM
Is there a "doner" vehicle out there i can look for to scavenge a rear disc set up from or would any 8.8 work or is there specialty items i would need to make 8it work?
06-25-2012, 06:33 PM
Yes i know proper spelling is donor.
06-25-2012, 06:35 PM
When I had considered the job I was thinking about using a late 90's Explorer for the donor parts. The rotors would have to be drilled for the truck bolt pattern, but the rest of the hardware should bolt up. The one disclaimer I'll put on this was I did not measure to make sure that setup would fit within the stock 15's, so a wheel upgrade may be needed as well.
06-25-2012, 06:40 PM
Thats a purty truck in that pic.
06-25-2012, 06:42 PM
Thanks....she's a pretty good runner too.
06-25-2012, 08:35 PM
Just saw you was a virginia boy. Im on the other side of the state where i64 crosses into wv
06-25-2012, 08:41 PM
Actually a RI boy transplanted to VA compliments of the Coast Guard. I've ridden the bike through your neighborhood on many occasions....beautiful country.
06-28-2012, 08:49 PM
If using the explorer brakes you will also have to grind down the edges of the axle flange as well as redrilling the rotors. They will fit in a 15" wheel
Galloping_Ghost
03-14-2009 04:56 PM
slayer272
01-05-2008 10:06 PM
Alrobot
08-23-2005 07:50 PM
EricFreeze
08-04-2004 03:08 PM
i0n
1978 - 1996 Big Bronco
10-22-2003 01:10 AM
