Oil Filter Adapter Gasket?
I need this gasket for a 2wd 75 F-100, it looks like its Ford part # D3TZ-6A636-A. I found the Felpro FPG 70135, but the holes in the middle don't look the same in the illustrations. I have not removed mine yet so I don't know what it really looks like. Just want to make sure that's it before I pull it off.
Thank's
Thank's
Ford has two different gaskets for the oil filter adapter.
The first is paper p/n C0AZ-6A636-B
The second is rubber coated steel p/n D3TZ-6A636-A
You can use either one.
Green Sales, Cincinnati, OH has 24 of the steel and 109 of the paper (800) 543-4959
Don Sanderson Ford, Glendale, AZ has 14 of the steel and 56 paper (623) 842-8643
There are a lot more available let me know if you want more names.
From the pictures I've found of the Felpro gasket, it's the same.
Green Sales is easy, you can check their inventory on their website. On the dealers I can check inventory through a parts locator service I have access to through work.
72CC428
04-29-2016 03:20 PM
dlmoore
10-23-2004 08:48 PM
3headedboris
05-10-2004 03:42 PM
Steve
01-18-2004 06:20 PM
1994, 351w, adapter, c0az6a636b, expedition, f150, filter, ford, gasket, oil, oil filter adapter, os, replacing
