460 efi build complete (thanks scotty@rRHP)
Old 05-02-2012, 08:14 PM
old96r's Avatar
old96r
old96r is offline
I am submitting this post post to give thanks to this site for its wealth of information and a special thanks to Scott (the mad porter) at reincarnation auto. Scott delivered quality products and most importanly without going into details showed himself to be the most honest and fair business man I have ever dealt with.
My truck is a 96 f350 4x4 reg cab long bed 37'' tires with 6" lift. I bought it after it was totaled by a previous owner. Like many folks I was looking for more power/torque out of it. So i gave the whole thing a 100% restoration that took 16 months or so. I took it down to bare frame rails. I gave everything on the underside a sand blast and 3 coats of POR15. The tranny is fresh as well as all the other moving parts under there.
I had Scotty send me ported and milled F3TE heads, ported intake and a cam and lifters set. I built the short block back as stock all new.
I added the following. BBK 1707 throttle body, BBK 1617 fuel pressure reg. set at 41PSI. K&N air filter, cut the air horns, L&L headers into 3.5 inlet/outlet magnaflow muffler. 180 deg. thermostat. I kept the O2 sensor and EGR. I removed smog pump and cat. Timing is set at 14 BTDC.
I really dont have have words for the difference in how this engine runs and the power it makes. I can say it will lay a 100 feet of rubber on the pavement from both 37 inch tires if I want it to. With this combination I did not need to add any chips and I am not having any computer problems setting off codes.
Anyway I just wanted to thank the site and its members for some mostly good and a little not so good advice. And share what I did with my engine from the ideas I found here. I put a couple pics in the album section 96f350
<!-- / message -->
<!-- controls -->
Old 05-04-2012, 11:14 AM
mustangman's Avatar
mustangman
mustangman is offline
thanks for the info, interesting, question on the bbk1617 i looked it up is it just a guage?.whats the regulator part # looking for adjustable regulator to replace the stock ford , thanks
Old 05-04-2012, 01:01 PM
old96r's Avatar
old96r
old96r is offline
I used a BBK 1707. The description is for a 94-97 mustang but it bolts right on the fuel rail in place of the factory regulator.
Old 05-15-2012, 12:02 AM
7DF250's Avatar
7DF250
7DF250 is offline
He is THE MAN when it comes to EFI 460's (or any 460 for that matter) I have learned so much just reading his posts and he hardly ever gives a one line reply to questions. I plan on having him do the head/intake work on mine if and when I ever get there.
Old 05-15-2012, 12:05 PM
mustangman's Avatar
mustangman
thanks again old96r, was wondering if the e4od can last with ur combo, you have the e4od?,on my f53 i would love to get a beefed up c6 to replace the e4od
Old 05-27-2012, 06:49 PM
nebechanezer's Avatar
nebechanezer
nebechanezer is offline
What cam and lifter set did you use? do you have any part #'s or specs?
Old 06-04-2012, 10:59 PM
Iversen-fords's Avatar
Iversen-fords
Iversen-fords is offline
how much work was done on the heads? also what cam did he use? You got me wondering now because i really wanted to do a this setup now also.
Old 06-18-2012, 09:04 AM
El Camino Man's Avatar
El Camino Man
El Camino Man is offline
Ill throw in a question too lol. Whats your estimated hp and tq?
Old 06-20-2012, 05:47 PM
nossliw's Avatar
nossliw
nossliw is offline
<!-- / message -->
<!-- controls -->
Do you mind me asking where he is located? I am in the middle of doing this to my 96 and sure would like to get my heads and intake done by someone who is familiar with these motors.
Old 06-20-2012, 08:38 PM
El Camino Man
Tacoma, WA
Old 06-24-2012, 08:10 PM
BrianDguy's Avatar
BrianDguy
BrianDguy is offline
I am also interested in the cam choice. Also, are you running speed density or mass air?
93f250tn
02-23-2013 01:54 AM
jokerforever
10-07-2010 05:49 PM
flitefreak
07-10-2009 01:39 PM
BigBlockF-250
04-11-2005 12:47 AM
mrsmith
03-14-2002 10:50 PM
Quick Reply: 460 efi build complete (thanks scotty@rRHP)
