1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
best oil for 6.8 triton v10
Old 02-27-2016, 05:44 PM
Sirgranticus's Avatar
Sirgranticus
Sirgranticus is offline
If ford recommends 5w30 full synth, why use blend? Also if they rec 5w30, why 0w30?
Old 02-27-2016, 06:18 PM
Sirgranticus
Nvm I'm reading Bob is the oil guy now.
Old 02-27-2016, 07:34 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
Ford does not specifically recommend synthetic oil. The current specs that Ford recommends are WSS-M2C945-A for 5W-20 and WSS-M2C946-A for 5W-30. There are many conventional, synthetic blend, and full synthetic oils that meet these specs. In fact, they don't even come with full synthetic oil from the factory. The factory fill in Motorcraft synthetic blend.
As far as 0W-30 goes, the main advantage here is in cold weather as it is thinner at cold temperatures. This means it will flow better and provide better lubrication when starting a cold engine, which is when the most wear occurs. Using Mobil 1 0W-30 as an example, if you look at the product data sheet you will see that it does in fact meet Ford's spec for 5W-30.
http://pds.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-30.aspx
Old 02-27-2016, 09:13 PM
Sirgranticus
So after reading the Bob guys article 0w30 seems to b the way to go for even summer time as he said with his average 75deg Florida morning. But as after his repedative diatribe I still can't decide why to go mineral, blend or full synth. It seems to be full synth is the way to go.. If so why do people use blend.
Old 02-28-2016, 03:29 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
it is cheaper
Old 02-28-2016, 04:15 PM
Sirgranticus
Ok that's what I was thinking but to me it makes no sense because of how important the oil is why would you cheap on it? I mean I understand saving money but its not even but 10 to 15 dollar difference. I could understand if it was 100 or even 50 dollars difference. At any rate I appreciate the feed back.
Old 02-28-2016, 09:49 PM
aortizexcursion's Avatar
aortizexcursion
aortizexcursion is offline
If it's one thing you'll see on Bobistheoilguy it's that you can really over think what kind of oil to put into your engine. Our Triton engines are fairly stout and not particularly picky. Use any 0W/5W-20 or 30 weight oil be it conventional, semi or full synthetic and you'll be fine.
Old 02-28-2016, 10:04 PM
darkjedi351's Avatar
darkjedi351
darkjedi351 is offline
Holy necro post!
you replied a topic from 06-25-2012, 05:15 PM
Old 02-29-2016, 02:31 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Originally Posted by darkjedi351
Holy necro post!
Nothing gets lost on FTE.
I use Motorcraft 5w20 synthetic blend and Motorcraft filter.
Pretty sure that is what the parts counter at the local dealer recommended when I first bought my truck.
Old 02-29-2016, 10:51 AM
Sirgranticus
Right about over thinking it, and yes thread is bit outdated. There's so many out there I have no idea how I arrive at the ones I do. Thanks for the reply
n3up
1997 - 2003 F150
13
06-29-2021 07:22 AM
bergy 2000
06-16-2011 08:19 AM
RetiredCDF'er
25
07-24-2007 08:18 AM
fordguyforlife
3.8 & 4.2L V6
10-27-2006 01:04 PM
khendrix
2004 - 2008 F150
06-06-2004 09:45 PM
Quick Reply: best oil for 6.8 triton v10
