A/C, fan clutch? my numbers are.....
07 Expedition w/aux rear air, 172,000 mi, well maintained.
92 deg days in south Florida I'm noticing A/C feels warm at idle but not bad under speed so I took some readings:
Engine off: 90 psi low & high, Amb 84 deg (Gauge Manifold is Mastercool brass)
doors open, a/c on max cool, fan high:
Speed 1500 rpm
Amb. 84F
Low 20psi
High 212psi
Vent Temp 58F
So I added 134a until I got the following:
Speed 1700 rpm
Amb 84F
Low 30 psi
High 275 psi
Vent temp 55F
@idle:
Low 40 psi
High 250 psi
Vent temp 59F
While @ idle or slightly higher I heard the fan clutch kick in (and wind noise), immediately the head pressure dropped to about 190-200psi, low dropped to 30 psi, and vent temp started dropping to 50F and below (48F) but didnt stay more than a few minutes.
Engine off, new high/low pressure is 96F w/ amb of 83F.
At ilde it almost looks slightly over charged. Shouldnt the fan clutch remain on at idle? How can I check or is it better to just replace? Not sure what cycles it, engine coolant temp? refrigerant head pressure? is there a way to test? IT was spinning the whole time while taking readings but there was a noticable change when it kicked in.
Thanks for any thoughts.
Speed 1500 rpm
Amb. 84F
Low 20psi
High 212psi
Vent Temp 58F
Speed 1700 rpm
Amb 84F
Low 30 psi
High 275 psi
Vent temp 55F
@idle:
Low 40 psi
High 250 psi
Vent temp 59F
OPCJeff
15
05-16-2018 11:28 AM
