About to throw in the towel
Over the last few months I went through the trials and tribulations of getting the newly rebuilt engine ready and installed back into the 52.
After fixing a few coolant leaks (from the water pump and thermostat housing bolts, as well as the upper and lower hoses) and replacement of a failed electrical fuel pump, we were finally ready to fire the motor. The motor had a healthy crank, but not able to start and run. We checked the spark, fuel, oil and compression. Found to have all but compression. We confirmed that the crankshaft and timing chain are installed correctly in proper timing. We also confirmed that each valve has the proper lash and is not stuck. We poured more oil inside each cylinder to lubricate and expand the rings. Still no compression.
I'm extremely disappointed right now. I called the engine rebuilder and he suggested that we do a leak down test and call him back. My buddy will bring over his tester tomorrow. I immediately checked my parts invoices and confirmed that I purchased the correct rings. Our guess is that the rings may not have been installed properly. At this point, I'm not in the mood to remove the engine again to haul it to the machine shop. I will definitely express my concerns to the machine shop and ask them to do all of the work.
It's really frustrating to spend all of this precious time and hard-earned money on something that doesn't work properly. I'm hoping that it's something simple.
_______________________________
2012 Ford F-250 King Ranch
engine
take a deep breath all is not lost most engine builders do and will stand behind their work it could be a very simple problem such as the valves are set too tight do a compression test on all cylinders if compression is none do a leak down test if air is coming out of the carb or the exhaust check valve lash if the engine was assembled by the engine builder call and talk the them for the most part they don't want to have any problems with your engine any more then you do they should and will most likely take care of you some time these are small problems do not let them get you down this is suppose the be fun hope everything works out
I am not an expert, but I don't think the rings will seat until the engine gets broken in. Given that fact, will a leak down test give an accurate indication if the rings are not seated?
On another note, we all have had our trial and tribulations with our trucks. Before you know it, you will be cruising down back road enjoying your truck.
The engine looks great Ilya. How low were the compression readings? If they were under 50 I wonder if the cam timing is off? You may have done this already but set your timing mark on the pointer then pull #1 spark plug and the valve cover and make sure that both valves are closed when the piston is at the top of it's stroke. If they put in a new cam you may want to follow the firing order and do that for each cylinder to make sure that you have the right profile cam. If it is cam related can't that be fixed in the truck without pulling the engine?
Next time, just go to the top of the thread and pull down the thread tool drop down, then click on subscribe. It took me a long time to realize it was there.
