Thanks....I'm pretty sure it came with the kit, but I could be wrong as it's been a while since I installed the suspension. May want to call chassis engineering to see if it's standard in their kits or if it's an add on.
Picked up a seat today from an older Ford ranger. Doesn't look like much but hopefully I can get it recovered reasonably because I think it will be a nice fit once I get the height just right.
Hello Tigerfan, just read your thread. nice build you have neighbor. I'm in Walker also, building 53 F100. One day I'll get around to starting a build thread. Good luck with your build
Thanks, same to you. Good to see local people on this board.
Looking good! I'm with you on the new bed from Midwest. Did you happen to pick yours up at Carlisle? I was behind someone that was loading one. Do you mind letting me know how you prepped the new metal before epoxy? I'm at that point and i'm not sure what is on the seemingly bare metal but since it's not rusting i'm thinking there is a film of some kind on it. I was thinking soap, water, drying, and then maybe a scotch bright before epoxy primer.
I wish I could of picked it up but unfortunately ended up paying freight. I used spi epoxy and just went over everything with 80 grit then used their wax/grease remover before spraying. So far very impressed with the quality of this kit.
After an almost 3 year period of no work being done on the truck, I’m finally back working on it. Here are some updated pictures of steering and brake work.
