19.5" wheels for 8-lug x 6.5" bolt pattern? - Page 2 - Ford Truck Enthusiasts Forums
Old 06-25-2012, 12:09 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
It is my personal theory that I've been suggesting on here for a while now.
Got to be careful because some vans had a d60 in them and not the 10.5"
The 4x4 vans I would assume use the same bolt pattern as the rear, so that would make it the old bolt pattern.
I've seen a number of 4x4 vans, but never had a tape measure to verify.
I wonder if any parts stores would have a 4x4 van front hub in stock to measure.
For the rear you may be able to use an OBS 10.25" hub and a van rear rotor.
Old 06-25-2012, 12:12 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Those rims on the dodge look like the railroad rims I had suggested. They are super narrow and are 19.5
Old 06-25-2012, 01:08 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
All vans had the d60 SRW or D70 DRW and kept the 8 on 6.5 pattern
Old 06-25-2012, 01:21 PM
jibronee
jibronee is offline
jibronee is starting off with a positive reputation.
Found what I was looking for. These are some pretty sweet wheels!
19.5x6 Polished Wheel American Eagle 58 8x6.5 | eBay
Old 06-25-2012, 02:19 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
I knew the semi-floating rear axle was a d60 but when I see a full float srw van it really looked bigger like a 10.5
Old 06-25-2012, 06:33 PM
portsample's Avatar
portsample
portsample is offline
portsample is gaining momentum as a positive member of FTE.portsample is gaining momentum as a positive member of FTE.
Thanks for the response(s). Unfortunately- I live in a somewhat remote part of Alaska and am reluctant to order a bunch of heavy iron w/out knowing for sure that it will work. I've done a fair amount of searching on web forums and have found no workarounds to put 8-6.5's on metric hubs without,
1) welding and redrilling the rims, or
2) using adapters.
I spoke with Fred at WheelAdapters.com, he indicated that adapters could not be safely used because the hole in 8-6.5 Ford rims is smaller than in the metric rims, and so would have to be machined.
Old 06-25-2012, 07:28 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Hold off a little while then.
I'm putting in a drw dana70 into my superduty soon. And I'll be looking to match the front wheel pattern. I'll do some leg work and try to figure it out for sure.
I'll post a new thread with the results.
Old 06-29-2012, 05:06 PM
jibronee
jibronee is offline
Check out this deal! Local were I live in Calif.
16.5" 8 lug rims and tires
Old 06-29-2012, 07:26 PM
Diesel_Brad
That is if you like 16.5 tires and bias ply at that
Old 06-29-2012, 08:06 PM
GNR22's Avatar
GNR22
GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
Yeah that's not really a deal...maybe if they were a new set of super swampers on 16.5" for $150..
harleymsn
Ford Truck Parts for Sale
16
12-15-2017 04:08 PM
truckdog62563
213
11-22-2017 05:40 PM
jibronee
12-08-2014 06:36 PM
jibronee
07-01-2012 10:01 AM
Sportscraft
WTB - Parts & other
03-15-2011 05:39 PM
Quick Reply: 19.5" wheels for 8-lug x 6.5" bolt pattern?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
