97 F150 Won't Fire
Old 09-10-2012, 05:48 PM
Truckmageddon's Avatar
Truckmageddon
Truckmageddon is offline
97 F150 Won't Fire
Can the GEM module cause no juice to the coil pack? I have checked every fuse and relay on the truck! PLUS changed the ECM (or main computer) at the RH kick panel. Any ideas or comments will be greatly appreciated.
Old 09-10-2012, 10:12 PM
critterf1's Avatar
critterf1
critterf1 is offline
Wrong section.
Old 09-10-2012, 10:36 PM
Truckmageddon
Thanks
Yep I realized that as soon as I checked my post. My brain did punch on the 97 section but the hand and mouse missed it.
Great forum.
Old 09-14-2012, 08:42 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,432 Likes on 2,347 Posts
Do you have any codes? No power means power isn't getting from the ECU to the coil. Look for a broken wire/bad connector. Look for a bad wire at the ECU plug also. Test thru the circuit for the open spot. Your key turns on the relay. Swap out the relay with a good one. Relay turns on the ECU and so forth.
Old 09-14-2012, 10:14 PM
Truckmageddon
Thanks PapaTiger,
The problem was a bad conn at the plug on firewall by the top RH side of engine. I went over and posted on the 97 up section and got a lot of advice. I had checked every fuse and relay multiple times and had it boiled down to the hot wire between the relay and coil pack. But didn't know it's route. Turns out you were right also! Lot of great folks on here. Thanks
Old 09-15-2012, 12:28 PM
Papa Tiger's Avatar
Papa Tiger
Those pesky connections!
roots4thought
05-19-2016 01:59 PM
86Stepside
18
06-04-2015 08:31 PM
bkrfrmhell
09-08-2007 09:09 PM
donald campion
01-02-2005 11:48 PM
cyberbyrd
Electrical Systems/Wiring
03-07-2002 09:00 AM
Quick Reply: 97 F150 Won't Fire
