Output Shaft Speed Sensor
Old 08-28-2016, 10:32 AM
Rob Cornette's Avatar
Rob Cornette
Rob Cornette is offline
Having a hard getting output sensor out(OSS).
I am limited on the work space and tools but should have what I need to get this sensor out and the new one in. But it seems I don't have the right size socket to fit the bolt holding it in. I have looked all over the internet and you tube to see what size or type of bolt this is but with no answers so could someone plz help
  #47
Old 08-28-2016, 01:03 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Clearly you didn't read this thread, as it says it's a 10mm in post 35 from our resident trans guru.
  #48
Old 08-29-2016, 08:17 AM
Rob Cornette
I did read all the posts and have tried a 10mm and an 8 mm. If I could figure out how to upload a pic I would show you what it looks like. It sure don't look like no 10mm that's why I asked the questions I did
  #49
Old 08-29-2016, 09:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Have you tried a 9mm? Someone could have replaced the bolt.
  #50
Old 08-29-2016, 11:53 AM
Rob Cornette
Ok update. I went to the Ford dealership and got the bolt issue figured out. The bolt is a star bolt. When they gave me the diagram for the sensor it hit me like a brick cause as soon as I seen the bolt it was the only tool I didn't try was a star socket set. So I have to go buy a set but thanks. First time for everything I guess.
  #51
Old 08-29-2016, 12:04 PM
Krazee Matt
That's odd, 6-pt is standard for those.
I didn't mean to come across as a dick earlier, you just posted asking what size without the back story you provided afterwards.
Glad you go it figured out! Stick around, we're a fun and crazy group of people
  #52
Old 08-29-2016, 04:31 PM
Rob Cornette
Another update. I replaced the OSS and she drives like nothing ever was wrong. Not saying that was the cure but for now it seems to be. I will let y'all know if anything else comes up though. Krazee Matt it's all good. I understand now where you were coming from. I am a little backwards sometimes and tend to tell things backwards. I was just trying to get the old girl back up and running that's all. I will stick around just because everyone seems to be pretty good folks on here. Thanks for the advice
  #53
Old 08-29-2016, 04:39 PM
Krazee Matt
FTE is one of the best forums I've been a member of, regardless of brand.
Check out the tech sticky link at the top as well. Tons of great tips, tricks, fixes, etc.
There's another sticky up there with 'read me first' in the title, second post has an intro walk through on signature, location, adding pictures, etc.
  #54
Old 08-29-2016, 04:55 PM
CharlyG's Avatar
CharlyG
CharlyG is offline
Right up there with The Gear Page and TalkBass.....musiciany forums I hang out on as well. Glad to be back on FTE, and done wit dat chebby!
  #55
Old 06-28-2018, 07:01 PM
Darrell Milgrim's Avatar
Darrell Milgrim
Darrell Milgrim is offline
output speed shaft sensor
​​​​​​​I have a 2001 ford sport trac that is coding OSS bad ford replaced it and it worked fine for 10 mins and od light started flashing again. It started two months ago and I would pull over and cut engine off and back on and it would shift great for a wk till od light starts flashing and shifts crazy till u get up to Highway speed runs perfect. Any help would really be appreciated my wife has ovary cancer so u know how tight money is.
  #56
Old 07-06-2022, 06:07 PM
Caleb_Tybursky's Avatar
Caleb_Tybursky
Caleb_Tybursky is offline
2nd Gear
Originally Posted by Mark Kovalsky
Yes, it is.
When you get it in, if it doesn't fix the problem come back and I'll help you find the real problem.
can you tell me how to?
devriesj39
1999 to 2016 Super Duty
30
06-26-2016 12:35 PM
jeffeff
05-04-2015 07:45 PM
marty722
17
09-02-2008 04:00 PM
Explorer98
05-30-2006 08:36 AM
flgal
09-20-2002 12:35 PM
Quick Reply: Output Shaft Speed Sensor
