67 Econoline Cooling question
Old 06-26-2012, 09:27 PM
Jippah's Avatar
Jippah
Jippah is offline
will the stock radiator in a 240ci van be enough to cool a 300ci?
I'm probably going to wind up buying a new radiator considering the stock one has been sitting since 1986 and who knows if the coolant had ever been changed in the entire life of the van..
also, i've noticed Offenhauser makes two intakes for the 240/300 block. any preference for which one?
i plan on having the stock 240 block internals swapped out with 300 internals and keep the 240 cyl head for a bit higher compression.
any suggestions for radiators? or intake manifolds?
Old 06-28-2012, 12:56 PM
Jippah's Avatar
Jippah
Jippah is offline
spose since they're the same block, a replacement OEM radiator will work fine.
possibly an aluminum one to save weight
Old 06-28-2012, 06:19 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
May I suggest calling US Radiator......they have been around for 40+ years and will answer any question you have and address any possible concern. I don’t know of anyone (including the racing community) who has not been pleased with them!
Link: U.S. Radiator | The Difference Is In The Tooling
US Radiator Corporation
4423 District Boulevard
Vernon, California
323-826-0965
Old 06-28-2012, 08:03 PM
Jippah's Avatar
Jippah
Jippah is offline
Awesome! Thanks Beechkid!
Raleigh234
11-17-2015 05:54 PM
Carmax
08-05-2015 02:05 PM
idealtrucks
09-05-2013 10:48 AM
Idaholar
1947 and Older Ford Trucks
10-02-2010 10:35 AM
BKB
03-03-2007 10:05 PM
Quick Reply: 67 Econoline Cooling question
