What should I do?
What should I do?
Hello,
I am seriously considering trading in my '11 250 gasser for a special order '14(when they start building them) 6.7.
So here are the pro's:
I can pull a house over.
I have a 38' gooseneck trailer the gasser pulls but when loaded its a bit much.
I can have it paid off by the end of the year.
Cons:
65-69 THOUSAND DOLLARS!!!
What do you gents think? Thanks in advance.
Cons:
Sounds like you're not happy with the towing right now, so I would say yes, if you can affoard the diesels price, and maintainance, go for it. I would certainly think you could negotiate a price considerably lower than 65-69 thousand though! My local dealer has a leftover 2012 f350 4x4 king Ranch on the lot right now for just under $50K
It isn't a business expense that I can write off. This would be my personal truck. The thing is, the gooseneck. I've have already maxed it out at 14,5K pounds. That is the max for my '11 250 gasser. I want that extra security if I do start pulling 14k on a regular basis. Lastly, the expense. I can afford it no problem. I'm just one of those guys that plans for a high price. I know the company I work for has one of those company discounts through Ford as well. I'm honestly thinking I should wait a year and see what happens.
OTOH if I had that much weight to pull that often and had the money I'd look for a diesel.
So I went through my companies corporate site and built the truck on there. I was shocked!! I almost swallowed my tongue. According to Ford the truck I built is 67,588 and change. According to our company site it is......you better sit down, 58,473 and change.
The model I decided to spec out is a SRW, Platinum. This is the order form. I'm still deciding on whether or not I should buy it.
Then I got to thinking(bad idea). Since there is only a 200lbs difference between the 250 and the 350, maybe I should go for a dually. I don't know...
- Platinum (17L)
- Lariat Series Order Code (618A)
- (4) LT275/65r20e All-Terrain OWL Tires (TCW)
- Solid Paint (-PT)
- Black Interior, Unique Platinum Leather 40/Console/40 Front Seats (7B)
- Tuxedo Black Metallic (UH-P)
- Gooseneck Hitch Kit (15J)
- 5th Wheel/Gooseneck Hitch Prep Pkg (53W)
- Dual Alternators (67A)
- 6.7l 32-Valve Pwr Stroke V8 Diesel Engine (99T)
- 50 State Emissions (425)
- Wheel Well Liner (61L)
- Pwr Sliding Moonroof (43M)
- Roll-Up Tonneau Cover (949)
- Bodyside Molding (965)
- Front/Rear Splash Guards/Mud Flaps (61S)
- Heated Rear Seats (90R)
- (4) Upfitter Switches (66S)
- Rapid-Heat Supplemental Cab Heater (41A-R)
- 3.73 Axle Ratio w/Electronic Locking Rear Axle (X3E)
- Fx4 Off Road Pkg (17X)
- Heavy Service Front Suspension Pkg (67H)
- 10,000# GVWR Pkg (6)
- Torqshift 6-Speed Selectshift Automatic Transmission w/Tow/Haul Mode (44W)
So why not a dually? More payload, gives you more capability in the future. Depends on what you think you might do and where you'd go.
I first thought I wanted a DRW as my next truck for more capability but then I had to squeeze into a parking garage in downtown Charleston (SC). Now not so sure.
My driveway could handle one, and everywhere I go with the truck I park further away anyway and take up two spots. I'm just one of those "what if" guys. Makes me lean more towards the SRW although a long bed I'd rather have for the utility.
What that probably means is eventually I'll have a DRW I'm just taking my sweet time getting there
I just got finished doing what you are talking about for the same reasons. I pull frequently with a trailer that had my 6.2 overloaded by Fords standpoint - but the truck would pull it just fine - Stop Fine - etc.
I also did what you are talking about and upgraded the interior ( man it is sweet ) with the Lariat package + Lariat Interior Pkg (Heat/Cool Seats).
I think that I made the right decision - but time will tell....
Good luck with your decision!
2011 - 6.2 White vs. 2013 Kodiak Brown 6.7
