Truck is a 1992 F-250 4x4 351W E4od.
When I first start the truck the CEL is off and stays off till you drive for about 2 miles or so. When I shut the truck off and try to pull the code there is nothing there
1st question is: Is this an ECm problem with not retaining codes or are there codes that will not stay in memory?
2nd question: any one have any idea where to start trying to figure out what is causing the CEL? I don't want to just start blindly throwing parts at it trying to figure it out.
At the very least you should get the "All Clear" code of 111/111. If not you may have corroded contacts on the Diagnostic Link connector or worst case a bad PCM.
