I'm building a shop!
#76
#77
Yeah...I knew you'd play that card, so I went and got this just for you.
https://www.ford-trucks.com/forums/1...l#post12027113
So to answer the question...YOU
#80
#82
#84
Except when it's a little nippley outside...then they're quite handy keeping the wind out. Speaking of kegerator...did you see that Rumarator they had on History channel for Sammie Hagar a couple of weeks ago?
#86
#88
Not sure how you can find it on History's web site; having trouble trying to find it on the site...but the name of the episode is "Right Here, Rum Now". I don't remember if he was using some kind of special brand.
#90
2 cents from a northerly neighbor.
I am trying to remember the sealer I used.....it stops oil, gas, trans fluid, and blood from staining the floor. Goes on with a roller and a 6 pk.
Watch out where the sparks from a chop saw go, that plastic insulation cover will melt. At least use a sheet of plywood as a back stop around the welding table in the corner.
Build a small room for the compressor and those want outa sight storage items, other wise you will need a powerful stereo to cover the noise.
Remember you can always add a lean-to on the back side later, for more room that you will need later.
Might as well be looking into how to mount a 6" I beam and get a trolley and 3 ton chain lift, or are you good with rolling around a cherry picker.
Get a few fire extinguishers from wally world, and add the building to your home insurance. A nice shop like that is worth the insurance cost.
You are wiring in 220 correct, if you do not have any 220 tools (compressor and ol HD stick welder or a new HP wire feed), you will someday.
Nice shop, they are never big enough. My 30x40 pole barn (initially w/30x20 concrete floor and enclosed) and a 12x40 lean to on the backside are full. I am about to concrete the other open 30x20 bay. Where the 6" I beam and chain lift already is......
Once again nice shop, I am jealous at the ceiling height you have, but heat rises so I kept mine at 10 ft side walls.
