I'm building a shop!
That's where I had it last night, and I deleted it at the last minute because I couldn't decide..
Yes we're on city water, and I plan to tie the bathroom into the existing septic. I'll also have another sink out in the shop for nasty stuff.. that one may not go into the septic.. not sure yet
I already have a 100A panel on the side of the house that was put in for the shop, and the water main already tee's and is capped off.
Jeff I forget did you get the A/C in the truck or are you running 2-55 A/C?
This heat and drought is just crazy. I dug up the water main which is about 2' down and it was like digging frozen ground the whole way.
I finally decided on 30 x 50 x13 with a 2:12 pitch. Between steel, concrete, and erection the difference between that and a 30x40 was about $2800
I'll sign the papers in the morning, in 2wks I'll have the Blueprints and around 6wks I'll have the steel. Right now I'm trying to decide if it's worth the extra $400 for a white roof vs. the galvalume.
#28
On the roof, I would go with the white, it will be cooler and easier on the a/c bill.
#29
