Using LEDs in our trucks.
#31
I did LEDs in my 97 (My 79 will be getting them soon) and love them. I also bought the bulbs from superbrightLED.com and haven't had any issues.
In the 97s they had a blue film behind the gauges and the incandescent bulb would shine through as green. So putting true white LED bulbs made the gauges looks blue (which is what I wanted)
#32
#33
The LEDs I put in my instrument cluster sure brightened it up and was well worth the changeover. I only did the back lighting, not the turns or the oil and alternator lights. I had some spare LEDs on hand then so I did the side marker lights, odd thing is that no matter what I tried I could only get the rear lights to work with the LEDs but not the fronts...??
#38
#40
#41
Look for 194 (T10) bulb replacements. I got mine on eBay from China for $1.50 each shipped. They work fine. At first I replaced all of my dash lights but the LEDs don't work well in all spots but like I said they sure do make the back lighting brighter like it should be. I might do my dome light some day, I was just happy to get it working after I bought the truck. It needed a new covet and new door switches, easy!
#42
By the way- LEDs have a polarity so what I did was I waited until dusk and I put my LEDs in so I could make sure they were in correctly before putting the dash back together.
The dash comes out easily, a few screws are on the top of the face piece and one screw by the light and wiper switch. The ***** for the radio and the light and wiper switches need to be pulled off. Then four screws for the cluster. The cluster has the speedo cable and a harness to take off if you want to completely take it out, not necessary if just putting in new bulbs, IMO...
#43
What bulbs are the ones that should not be replaced with led's, in your opinion? Thanks for your help just don't want to do the job twice.
#44
From what I am seeing you just need to get the right LEDs. Some LEDs point straight ahead, some throw light in a 360 degree pattern. You need the kind that throw more light around from what I have seen.
#45
At first I did all of the except the turn indicators. A posting earlier in this thread explains why not to do the turn indicators. The oil and alternator lights didn't work right so I changed them back to the incandescents. No biggy, they are just fine with the old bulbs. The bright headlight indicator might work ok but there again mine is ok with the old bulbs... If you buy a kit from a web site it may work in these locations. I just bought some 194 LED replacements online. I am getting about five times more light fom the background bulbs now and that's what I really wanted!
