Old 11-21-2014, 10:48 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all:
Print Wikipost
Engine vibration starting at 1,500 rpm and ceasing at 2,300. Ideas?
Old 06-16-2012, 01:49 PM
MudhenGIB's Avatar
MudhenGIB
MudhenGIB is offline
At idle it's minor, at speed it's very noticeable. Also, t start up my FMP on SGII is between 39-43, then after it the truck warms a bit, it settles between 47.5-49.0.
Any help is much appreciated. 2005 6.0L stock engine/tune/exhaust.
Thanks,
Matt
Old 06-16-2012, 03:57 PM
cheezit's Avatar
cheezit
cheezit is offline
matt odds are you have an injecotr going out and you need to get the ficm fixed
Old 06-16-2012, 04:25 PM
MudhenGIB's Avatar
MudhenGIB
Thats what I figured. I won't drive it until I do. What was the name of the company that you ship your fcim to? I'm not popping any codes on SGII, shouldn't I be?
Old 06-16-2012, 05:44 PM
cheezit's Avatar
cheezit
cheezit is offline
ficmrepair.com.
Ed's good people and fun to talk to on the phone.
with injectors you may or may not get a code.
Old 06-16-2012, 05:58 PM
foul1's Avatar
foul1
foul1 is offline
I had same symptoms, ended up with broken injector bolt in the oil pickup tube. I drove it too long probably after the vibrations started.
Old 06-17-2012, 12:30 AM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Make shure charging system is up to Par
a Bad componet in the charging/Batterys will Kill FICM Fast
Old 06-17-2012, 12:33 AM
joe blow's Avatar
joe blow
joe blow is offline
I just dealt with Ed and he is great. He did mention something very interesting about the underpowered alternator. He suggested a good 140A or greater.
Old 06-17-2012, 09:54 AM
MudhenGIB's Avatar
MudhenGIB
Just throw a volt meter across the alternator to check? Or is one of the gauges on SGII sufficient?
What's the best way to determine if a fuel injector is failing/sticking if it's not popping a code?
Old 06-17-2012, 10:07 AM
MudhenGIB's Avatar
MudhenGIB
ficmrepair.com.
Cheezit, would you work for pizza and beer to come up to the Falls to help fix my truck? Kidding. What dealership are you at, if you can say?
Old 06-17-2012, 01:11 PM
MudhenGIB's Avatar
MudhenGIB
Please take a look at this video and let me know your thoughts. Definitely appears to be FICM.
Thanks,
Matt
2005 Ford F250 6.0L cold start, plus 4 minutes - YouTube
Old 06-17-2012, 01:31 PM
BLADE35's Avatar
BLADE35
Oh ya the FICM needs work
Your Alternator Looks Weak or a Bad Battery is dragging it down
Mine Volt readings will jump to 14.0-14.3volt when the GP turn off and when done charging settle to 13.6-13.8volt
Have batterys Load Tested I would bench test alternator too
Im thinking your Batterys or alternator are getting weak and caused stress to the FICM what KILLED the FICM
any battery light flicker on the Dash???
Old 06-17-2012, 01:35 PM
BLADE35's Avatar
BLADE35
I wouldnt worrey about injectors yet
you cant Diagnos a BAD Inject with a Bad FICM I mean the result maybe Skewed or Biased because the inject controller is Bad
Old 06-17-2012, 01:37 PM
MudhenGIB's Avatar
MudhenGIB
Wilco on battery, FICM, and alternator... But if not bad injector, why the vibration?
Old 06-17-2012, 01:51 PM
BLADE35's Avatar
BLADE35
Im NOT saying that you DONT have a BAD Injector
Im just saying that since the FICM isnt up to Par that the FICM could be Messing with an Injector operation
Just a Chain of Events one thing Fails and could Screw things up Down the Line and may or maynot Kill other parts down the Line
In this chain of events the FICM comes First so I would address it First and the injectors may start to operate Normal or if they to far gone you might need an NEW Injector
Old 06-17-2012, 03:20 PM
MudhenGIB's Avatar
MudhenGIB
Ah, got it. I did not realize a bad FICM could potentially cause the engine roughness. Thanks do much for your help, already in email contact with Ed, and will be removing the FICM today. I'm going to get a battery minder, and test/charge the batteries, or buy new ones, and test the alternator.
Thanks again. Will post results.
Matt
shultzaberger
10-17-2014 08:30 AM
berry1234
Modular V8 (4.6L, 5.4L)
05-09-2012 05:05 AM
zamunda
10-14-2011 03:23 PM
sixamskier
10-21-2009 08:40 AM
dreed
2004 - 2008 F150
08-12-2004 04:36 PM
Quick Reply: Engine vibration starting at 1,500 rpm and ceasing at 2,300. Ideas?
