47 Ford 3/4 ton Truck - Ford Truck Enthusiasts Forums
Old 06-15-2012, 09:52 PM
James T
James T is offline
James T is starting off with a positive reputation.
Question 47 Ford 3/4 ton Truck
Does anyone know where I can find a 17 inch, 5 lug, split rim wheel for my 1947 Ford 1 ton truck? Center hole is 4-3/4"; Lug pattern is 4-1/4" and Stud hole is 7/8".
Last edited by James T; 06-17-2012 at 05:54 PM. Reason: correction the original posting
Old 06-17-2012, 03:55 PM
46fordtruck's Avatar
46fordtruck
46fordtruck is offline
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
James, welcome to FTE, hopefully your wheel search will be successful. There are a handful of members here who have these 1 tons. There is no such animal as a '47 3/4 ton. They were dropped after the War until the F series was introduced in '48.
Good luck looking for it, hopefully somebody here can help you out.
Old 06-17-2012, 05:51 PM
James T
James T is offline
Gary thank you for the information. Jim
Old 06-18-2012, 10:07 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
There were two 17" rim widths available on the tonner wheels having the 5 x 6 7/8" bolt pattern. One was 3.75" and the other was 4.33". The 3.75" was Budd #44620/Ford #11Y1015B, and the 4.33" was Budd #44630/Ford #11Y1015A. While they both use the Firestone "RH" style outer rim with solid/unbroken locking rings, the rings on these two wheels were not the same part number. The one for the 3.75" rim is Budd #32639E12, and the one for the 4.33" rim is Budd #32639E11. They don't interchange, and every wheel reference I have cautions to not combine non-matching rims and rings.
While you've not said why you need just one wheel, what I've found is that the rims will rust out when allowed to sink into the mud, or develop rust between the disc and the rim around the rivets. Commonly, though, when this happens the outer rings aren't always as badly damaged. I have a similar NOS wheel (different size) and it's pretty clear the "RH" locking ring on that wheel was galvanized or otherwise plated to protect it. If that's your situation you might be able to reuse your ring.
Right now on ebay there is a listing for a NOS 17" tonner wheel having the 5 lug x 6 7/8" pattern. Problem is the wheel doesn't have the locking ring with it, and he doesn't say what the rim width is. If no member steps forward with a good used complete wheel for you, and if your ring is still good, you might quiz the ebay seller about his wheel to see if it would be permissible to combine it with your ring. There should be a Budd part number on the wheel. The rings were numbered too, but they located these along the back edge right where they tend to rust, so it's not often easy to read the ring numbers. Stu
Ford Truck 17" wheel 1938 -1947 NOS use 700-7.50X17 Fits Ford Panel & Express | eBay
Alanok
1947 and Older Ford Trucks
21
06-30-2016 06:51 AM
Craig46
35
12-19-2015 03:16 PM
TavernMonk
2004 - 2008 F150
09-27-2014 07:48 AM
jayzad
02-27-2013 07:11 AM
Alanok
Ranger & B-Series
04-11-2005 12:16 PM
Quick Reply: 47 Ford 3/4 ton Truck
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
