9" spool install
Old May 6, 2003 | 10:31 PM
rustyolred27's Avatar
rustyolred27
9" spool install
i just purchased a spool for my 81 f-150 with a 9" rear. do the r&p gears need to be re-setup after the spool is installed or just bolt the ring gear on and go with it?
Old May 7, 2003 | 09:16 AM
John Barleycorn's Avatar
John Barleycorn
9" spool install
If it's a full spool, yes, you need to setup the gears. If it's a mini spool you don't.
Any time a carrier is changed the gears should be setup.
Old May 7, 2003 | 02:43 PM
TallGuy_Az's Avatar
TallGuy_Az
9" spool install
You are gonna like the off-road abilities after you install that thing. I love mine.
Old May 7, 2003 | 08:19 PM
rustyolred27
9" spool install
it's actually a mini spool in a new carrier. so set up or not set up?
Old May 8, 2003 | 08:41 PM
rustyolred27
9" spool install
bump...............please help
Old May 8, 2003 | 11:50 PM
millertime300's Avatar
millertime300
9" spool install
You do not need to set the pinion depth, you do need to set the backlash. All you need is a dial indicator, or can do it by feel. Just make is feel like it did in the first place. It is the easy part of a gear set-up. Do use a dial indicator if you have one. If not you can look at the tech articles, one of them says the correct backlash, you can use a set of feeler gauges instead of a dial indicator. (they cost about $2)
Oh and by the way, your going to love it.
