6 inch Skyjacker Lift Questions
Thank You! I will consider that if i'm ever forced to leave Sunny SW Florida for Pa. and odd's are Pa won't be my next vacation destination.
But to answer the question , what are the laws down there ? Incase I'm ever forced to leave here ! I see a lot of crazy stuff on the road down there.
My truck is nothing the law would even look at here but I will ask just so I can share the correct info. I saw a guy with a 60's VW Bus with no glass, he was wearing goggles! I guess there's no law's. Really, we have lot's of Hotrods, Ratrods,Customs,Big Trucks and No Smog! The air is clean and as long as nothing gets out of control all is good. So I guess driving my truck to the local burger joint every Fri. Night to gather with other's would be a problem in Pa? I'd move.
How much does your plate cost a year down there ?
Yea, the local cops can be the worst too. I just did everything I had to do to mine to keep them off my back, I'd like to get 44's next but there is no way I could cover them on the front axle good enough to not have any problems. A friend of mine has 44's on his '78 and every time he goes out it seems like he ends up taking them off for the warning to go up and show them he doesn't have them on anymore, of course as soon as he gets home he puts them right back on. A 3/4 ton has to be no more than 28" in the front to the ground, rear 30". The tires can not stick out of the fender wells and you have to have full mud flaps. I got around the smog stuff, I got a Collectable plate for mine so it's smog exempt and I have a permanent registration, no more yearly plate fees.
Never checked, no smog here but may help insurance.
Skyjacker 6" all four leaf springs, Skyjacker kit that replaces all springs still retains factory rear blocks. Skyjacker gas shocks a bit stiff. Braided S/S brake lines 8" over stock custom made local. Front driveshaft lengthened 2 &1/2" new spline end, cardin rebuilt. Rear DS stock. Steering, 4" drop pitman, Skyjacker drag link, steering arm block, Skyjacker dual steering stabilizer, HP D44 rebuilt, ball joints, wheel bearings, spindle bearings, Chrome Molly stub axles, Warn preimum locking hubs seals, etc. Super Swamper IROK Radials 39.5 x 13.5 x LT16 on M/T Classic II's I drive this truck every day with an Endless Smile. hp d60 kingpin front axle ready soon for install. The end result is a truck that runs smooth 0-80+
Your truck looks great. Mine on the other hand not so much. I guess spending all of your life being a farm truck and pulling a cattle trailer takes it's toll. I wanted to make the truck safe and a good driver so I bought the Skyjacker dual steering stabilizer and steel braided brake lines. Ball joints, tie rods, and wheels bearings are all tight. It needs some front axle seals though. I'm gonna be running 35 inch boggers for now and keep a look out for a decent set of 38.5. I'll post a couple pictures of the truck in it's current state if anybody is interested.
Yea i'm going to do the regear myself so i'm rounding up parts and a spare rear housing so I don't have to tear mine down plus I want to do rear disc brakes at the same time.
#30
Well I moved away from the 5's and started to juggle 4.56/4.88 and I think the 4.88's (your advice correct) stayed on top. I think with the C6 and the 203/205 doubler you might have to beat the smile off my face with a mud flap, one of those "Big Sky Country" mud flaps ---><---
