My 1983 F100 restoration thread (WAS: Per request of Mr. Gary Lewis)
#31
First of all, thank you to all of the veterans out there... no need to thank me for YOU paving the way so I could follow your footsteps.
On the other hand, thank you guys for your compliments... wasn't really what I was after, but makes me feel good inside.
What I am really here for... Mr. Gary Lewis, you asked when I almost stole a thread and you shall receive.
Speed Pro ZL2379F40 - Speed-Pro Forged Pistons - Overview - SummitRacing.com
COMP Cams 31-414-3 - COMP Cams Magnum Hydraulic Camshafts - Overview - SummitRacing.com
Other parts that I do not really consider "power adders" (more like necessities) are the common Edelbrock Performer RPM, Holley quad carb, new distributor such as....
Proform Parts 66969R - Proform Street/Strip HEI Distributors - Overview - SummitRacing.com
Other Miscellaneous things such as good lifters, good set of rockers (does not matter what brand as they all do the same thing... I do remember that I got the same as stock ratio... just roller for about 160 bucks I believe {1.5 or 1.6 to 1} I cannot remember) everything else in the engine is stock. Please remember those numbers are "nominal" from a computer program at 100% volumetric efficiency.
Anymore tests for me?
#32
And, it should be 8-pages long. And not a micro-analysis.
Oh, and it should have been "grammar, English, and spelling". I was once told by my West Pointer room mate (no, I wasn't at the Point, he had been) that the use of a comma behind the penultimate item in a list is the "Boston comma", and few people subscribe to that theory. I guess that sums me up - outstanding by myself. Or, is that "out standing by myself"? I never seem to get that right.
Lol, sorry about that but I had to!
#33
What about heads? What compression ratio? Carb?
#34
Thanks. Wasn't a test, I was curious what components you'd chosen. That's more duration than I'm comfortable with as it'll raise the RPM at which the power comes in. Ditto for the intake. But, depending on how you are going to use the truck, and what transmission and gears you run, it should scream.
I did recently pull that cam and replace it with the comp cams 268H that I had in the shop along with putting the 390 CFM back on in hopes of restoring some city drivability/economy. (it worked by the way)
You are right though, it would pull all the way up to 6000 at least. I am very surprised the stock lower end held up to it, and I do not think I will be pushing it that hard ever again. I will be building my 351w block for the fun and have the 302 for back up.
#35
Semi stock heads (a little home porting/port matching with machine shop valve job). Compression ratio is around 10 to 1... just about right for a dynamic comp ratio for 87 gas with that cam. Carburetor is an old 600 CFM that I had laying around and rebuilt when I found my 390 CFM stumbling a little at top end.
But that was in an 82, which I sold when I got Dad's '81, and that was the last year for the M. So, I'm into the 335 Series engines now and have been impressed with them.
Anyway, you can get a lot more torque out of a 351 than you can a 302 unless your budget is big. And torque is what trucks need. I'm sure you'll like it.
#37
I was taught the last comma before the word and is optional. There are some cases where it helps clarify the intention but those cases are pretty rare in my experience.
I'm sure Gary will argue, we both seem to not agree on the content of Elements of Style.
Sorry for the hijack.
As for Elements Of Style, I have the book - somewhere. But, I got mine early in my career so it is quite old and English has changed since then. I think mine uses "thee" and "thou". Hijack is over, again.
#38
#39
I have rolled this idea around in my head for a little while now and I want to get some input on it just for grins. I want to make a custom bed cover out of polished aluminum tread plate. I know this is not very cost effective but it would be a total of about $500 bucks the way I plan.
Quick crude drawing of my plan. (in ms paint) I will draw this in AutoCAD before actually doing it.
https://www.ford-trucks.com/forums/p...ctureid=102973
I am going to talk about this like I have already built it but this is my mental picture of how I plan to make this happen.
First make a frame around the bed out of 1.5 x 1.5 x 0.125 aluminum square tubing. After that, interconnecting bracing and cross pieces of the same tubing. I am assuming I will need about 60 feet of tubing with my crude/guessing measurements
Second, have a sheet of aluminum tread either 0.125" or 0.062" thick plate cut for the exact size that I will need to overlay the outside perimeter of the bed.
After that all will be notching, bending and some tigging.
For the hinges, My idea was to use late 60's style mustang hood hinges with springs (if that doesn't lift it, I will purchase some cheap hydro-assist shocks found on newer cars from autozone.
My idea incorporates the bed rail cover idea extending and rolling down the top of the bedside a little like in the link below.
http://www.cardomain.com/ride/382289...-4#38228984138
I have not thought of a lock for it yet but I am sure it will come to me magically after this post.
#40
#41
I do plan to have a lip on the tailgate, again similar to what I currently have.
#45
