Which Transmission? 1999 250LD 4X4?
My Truck is a 1999 250LD 4X4 with a 5.8
Transmissions take 3 different fluids, depending on which one.
There is no way to look at the sticker on it. The heat shield is right up against it. The pan says "Metric" and "gasket is reusable". It has 73 stamped at the forward edge of trans. The bottom edge of the build tag under TR says "E" I take this is transmission code? I want to change to filter and fluid. I just need to figure out which one is in the truck!
alumcanTandThd
04-02-2023 03:06 PM
SoCalAngler
19
03-13-2022 01:29 PM
wgw
1999 to 2016 Super Duty
04-23-2002 10:05 AM
