3 Valve V10 or 2 Valve? - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 06-12-2012, 10:47 AM
bcpape
bcpape is offline
bcpape is starting off with a positive reputation.
Question 3 Valve V10 or 2 Valve?
Hello- Does anyone know how to tell if a certain V10 has the newer 3 Valve Heads? Here is the situation - I currently own a 2004 Excursion with the 6.0L PowerStroke. It's a great truck and I like the power, but it's beginning to bleed me dry financially. I've decided to move on. What I would like to find is a 2005 Excursion with a V10. However, after hearing the horror stories of the V10's spitting spark plugs and popping exhaust manifold studs, I have been told that I should only consider a 2005 because that was the first year of the 2nd generation heads with the 3 valves. Is what I hear correct in that the 3 valve heads DO NOT have the spark plug issue? I am limited to the 2005 model year because that happens to be the last year of the Excursion. While the v10 lived on, the Excursion did not. I need the power for towing and I would melt down a 5.4L. What say you all? Should I pursue the 2005 Excursion or move on to a Suburban with a 8.1L? Thanks in advance for your opinions.
Old 06-12-2012, 12:58 PM
donovan
donovan is offline
donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.
3 V
The 3v will have more power. 05 and up would be the 3V.
On the spark plugs ford did add more threads to the the head for spark plug before 05. The best way to tell if your not sure is look at the EPA sticker on the engine.
The rating on 2005 and newer is below.
2005–2010 Ford F-Series Super Duty, 3-valve SOHC, 362 hp (270 kW) and 457 lbft (620 Nm). 2011 MY only available for F-450 & F-550 as a Chassis cab.
Old 06-12-2012, 04:08 PM
jade97's Avatar
jade97
jade97 is offline
jade97 is starting off with a positive reputation.
A 2005 Excursion will have a 2v v10 or 2v v8 (gas models) or the 6.0 diesel.
Old 06-12-2012, 04:50 PM
bcpape
bcpape is offline
You are correct - Thank You
Yes, you are correct. Had a lengthy conversation with my Ford Dealership. Apparently there is a "middle" generation of the V10's. The early engines had the 2 problems with spitting out spark plugs and snapping exhaust manifold studs. There was a revision of the heads that gave more thread contact area for the spark plugs. He was not sure when that occured, but thought it was around late 2003. Those heads appear to be most sought after. Then came the 3 valve and that brought about new and improved problems. Spark plugs actuall snap off in heads. He told me a 2005 V10 prior to the 3 valve heads were the ideal engines. Sort of like the early 2003 Excursions with the 7.3 PowerStroke and not the garbage 6.0L like I have...
Old 06-12-2012, 08:35 PM
dualwheels66
dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
Don't let spark plugs scare you away. The 3v only had bad plugs from the factory and even then it was only up to a certain build date. The plugs that break are a 2 piece design, Ford has a one piece design that has been available for a long time. My truck has a build date of 9-07 and had the one piece plug, changed all ten in 90 minutes. Do not let your plugs stay in longer than 50,000 miles.
Old 06-13-2012, 08:53 AM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
If you look through the tech folder, I believe I have the spark plug information in there.
The Excursion never got the 3-valve V10.
An easy way to tell is the 2-valve has plastic valve covers, the 3-valve has aluminum valve covers.
Old 06-13-2012, 09:22 AM
bcpape
bcpape is offline
Thanks for the help!
Thanks for all the clarification.
Old 06-14-2012, 09:42 PM
bakon
bakon is offline
bakon is gaining momentum as a positive member of FTE.bakon is gaining momentum as a positive member of FTE.
Had a 99 which blew a plug. Short thread area.
Have a 2003 with more threads and still blew a plug. Also has needed exhaust manifold stud work.
Good news, the newer head did not need removed to fix. Snap on has a set of inserts and tap which can be fixed on the vehicle. Takes a mechanic which has experience with this and the snap on set but it is not a big deal and once fixed it takes a standard plug. My 2003 has a one piece plug, so I know nothing of the later 3 valve head problem.
bismic
05-17-2017 03:42 PM
Navigator777
08-31-2016 05:35 PM
murphym84
10-05-2012 02:14 AM
nannerann66
04-05-2011 09:32 PM
V10Pride
Modular V10 (6.8l)
20
07-26-2010 12:27 PM
Quick Reply: 3 Valve V10 or 2 Valve?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
