59 f 250 transmission
Old 02-05-2015, 04:06 PM
Mercury59's Avatar
Mercury59
Mercury59 is offline
Mercury59 is starting off with a positive reputation.
Yes, I forgot to mention that part didn't I, there's a guy that has the whole set up I'll need and he fabricated a bracket and welded it on, he said it was fairly simple, I just didn't wanta do it that way, but it'll all work out, thanks for your input man, I was already told it wouldn't work the way I wanted, but I just had to get at one more opinion on it.
Mercury59 (Gord)
Old 02-05-2015, 04:55 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
Now you are just down to figuring out the drive shaft. The T85 I have uses the large yoke 1.680" OD approx. I don't know if all T85's had that or the more standard 1.5"
Old 02-05-2015, 05:12 PM
Mercury59's Avatar
Mercury59
Yes, But first I still want a 3 speed with OD that will work with my bell housing, and I just read about a T86 G or H that was in Fords from 58 to 64 so I'm going to do some more searching to see if I can find one of these.
Mercury59
Old 02-05-2015, 06:25 PM
hiball3985's Avatar
hiball3985
Mercury59
If you can find a truck trans with OD thats the easiest way to do it.
Old 02-07-2015, 06:10 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
But I want a 3 speed with Overdrive that will work with my bell housing, and I just read about a T86G (223) or H (239/272/292) overdrive that was in Fords from 1958/64...
B8C-7505-A .. Bell Housing / Obsolete
1958/64: F100/250 with 3 speed Light Duty 239/272/292 / F100 with Warner T-86H 3 speed Overdrive 239/272/292 / F100/250 with Warner T-89 3 speed M/D 239/272/292.
B8C-7505-B .. Bell Housing / Obsolete
1958/64: F100/250 with 3 speed Light Duty 223 I-6 / F100 with Warner T-86G 3 speed with Overdrive 223 I-6 / F100/250 with Warner T-89 M/D 3 speed 223 I-6.
Old 02-07-2015, 06:35 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
bigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant futurebigwin56f100 has a brilliant future
If you want to use your 4 speed bell, You could install a 5 speed OD. They came in some trucks (larger trucks f600 etc) I believe they were Clark 5 speeds but I have been wrong in the past. BTW I have one of these transmissions here already out
Old 02-07-2015, 07:27 PM
Mercury59's Avatar
Mercury59
I thought about using a Clark 5 speed with OD, but the two I have are just Reg. standards, one out of my Mercury 700 and one outta my F600, and I have 3 T98s. I'm still thinking of putting one of the Clarks in my Mercury 350 flat deck, but a Clack with OD might not be a bad idea too, at this point though I've decided that the T85 with OD is what's going in my 59 Mercury 100. I've met a guy that has a bell housing and tranny, I'll have to do a bit of fabricating for a trans mount, and get a driveshaft made, but I think it'll work out just fine. but we could talk about your OD Clark. send me a message,
thanks,
Mercury59
Steven Leisenring
1999 to 2016 Super Duty
02-15-2016 08:48 AM
Steven Leisenring
Projects
02-08-2016 03:48 PM
nickdellamore
08-19-2010 09:54 PM
59 F250
02-22-2004 11:32 PM
ahkmn
Offroad & 4x4
09-11-2003 04:41 AM
Quick Reply: 59 f 250 transmission
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
