Speedometer for a 58 Ford F100
Old 06-10-2012, 12:18 AM
bchecjon's Avatar
bchecjon
bchecjon is offline
I have a 58 Ford F100 Styleside Pickup and am having a lot of trouble finding a speedometer. Does anyone know where I could get one, or a reasonable replica?
Thanks
Old 06-10-2012, 05:08 AM
2quickM100's Avatar
2quickM100
2quickM100 is offline
Where are you located?
Old 06-10-2012, 08:20 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
If you'll monitor ePay daily,you'll eventually come up with one.I see NOS ones come up 3-5 times per year.They go fast, and they go high,so if you want it bad enough,you don't whine, just open your wallet.I believe the entire range of years will interchange, but there are differences in the color of the face.I bought an NOS one, it sat on my shelf for about 5 years till the original finally bit the dust.I swapped them out, had the original re-built,and now IT sits waiting on the shelf, where it will probably remain till needed again - when I'm about 75 years old - it lasted over 50 years on the first go-around.
Old 06-10-2012, 07:06 PM
spurredon's Avatar
spurredon
spurredon is offline
Here's one that just went off Ebay, he may well still have it.
1950-60'S FORD F-SERIES TRUCK OEM GAUGE CLUSTER RESTORE, RESTOROD, HOT RAT ROD | eBay
Old 06-10-2012, 10:04 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
He pulled the listing. I see the complete clusters go around $200.
Old 06-11-2012, 06:44 AM
3414's Avatar
3414
3414 is offline
Could you use one that has miles on it already? I have seen clusters on Ebay go for anything from $25 to $250. Often incomplete clusters that have the speedometer but are missing other gauges, the glass, etc. go for the least. I am a bottom fisher, and sometimes pick one up that no one has bid on to get a particular part I am after.
How soon do you need one? I might have one in the barn, but due to my schedule I may not get out there till the end of the month.
Old 06-11-2012, 11:30 AM
a4t1rat's Avatar
a4t1rat
a4t1rat is offline
I have a few good used ones. PM me if you are interested.
oldmanrvr5
08-25-2014 12:52 AM
Pickupman69
03-24-2012 07:07 PM
Fiddy 6
08-09-2010 09:00 AM
f100swe
02-04-2008 01:25 AM
rickfixit
05-23-2007 10:54 AM
Quick Reply: Speedometer for a 58 Ford F100
