An interesting note about high octane
Old May 6, 2003 | 04:49 PM
steve83's Avatar
steve83
This is off the Ford service CD:
Rough idle, hesitation, poor throttle response, induction backfire and stalls during cold start/warm-up may be caused by the poor volatility of some high octane premium grade unleaded fuels (91 octane or higher ([R+M]/2). When compared to regular grade unleaded fuel (87 octane), high octane premium grade unleaded fuel may cause long crank time.
Use a regular grade unleaded fuel in all vehicles, except where a premium unleaded fuel is recommended in the Owner Guide. If lean air-fuel type symptoms are experienced, determine the grade and brand of fuel used and offer the following service tips.
- Advise those using a higher octane grade fuel to switch to a regular grade unleaded fuel. For those using a regular grade fuel, advise them to try another brand.
- Do not advise using a higher octane unleaded fuel than is recommended for that specific engine. Ford engines are designed to perform best using a high quality regular grade unleaded fuel.
- Advise using a higher octane unleaded fuel to avoid potentially damaging spark knock or ping, but do so only after mechanical repairs are ineffective.
NOTE:
All unleaded gasolines used should contain detergent additives that are advertised as having "keep clean" or "clean up" performance for both intake valves and fuel injectors.
