6.2L V8 Discuss the 6.2L V8
1/4 mile performance
Old 06-07-2012, 06:59 AM
Racer5349's Avatar
Racer5349
Racer5349 is offline
Anyone have a timeslip on a new 6.2 yet? I'm planning on Saturday, June 9th to see what my new F-350 CC will do in the 1/4 and was curious as to what others might have already run. I have 3.73s and a completely stock truck so I don't expect blistering times, but it would be nice if I could outrun the '10 Mustang GT my wife stole from me that went 13.86 @ 100. I'll be happy if I can get a 15 out of it.
Rock Falls Raceway, Eau Claire WI
Rock Falls Raceway
Another forum member will be running his studded '07 F250 6.oh-no the same day. Should be fun.
Old 06-07-2012, 07:07 AM
Strokt350d's Avatar
Strokt350d
Strokt350d is offline
Well, I haven't seen times, but I can tell you that if your in regular shift mode, when it shifts from 1st to 2nd, the rpm's fall so far back, your way out of your powerband. You won't run a good time at all. Truck loses everything right there. I would recommend manually shifting it, and definatley do not shift it off the rev limiter. Hit the button. Like as soon as it comes past 5k or so. It will end up shifting at 5500 or so. You might need to play with that receipe
Old 06-07-2012, 06:57 PM
Longbed Lightning's Avatar
Longbed Lightning
Longbed Lightning is offline
I ran mine and it went 15.18@92mph. I had massive wheel hop and spin off the line. I ran it in tow/haul*mode and it seemed to shift right close to 6K RPM's.
Old 06-08-2012, 06:32 AM
Racer5349's Avatar
Racer5349
Thanks for the info. Looks like I will be happy to put it anywhere in the 15s. I hope I don't get the wheel hop so bad, but all of my other trucks did it too. I launched those in 4x4 and switched back to 2wd about the 60' mark.
Old 06-08-2012, 06:35 AM
Strokt350d's Avatar
Strokt350d
That's an F150 though, accroding to your SIG. Right.
I did some experimenting this morning. My take is hit the button when you see 5200-5400 or so. Closer to 5200 because I'm betting the peak power band is not 6000.
Check dyno sheets on 5-stars website maybe.
Old 06-08-2012, 06:48 AM
Racer5349's Avatar
Racer5349
Yup, I saw that his is a 150, so I'm hampered by a ton (literally) of extra weight and realize I won't run even close to low 15s. I've been throwing chit down dragstrips for a long time and it usually takes me 6-8 runs to get the most out of it, so I hear what you're saying and agree. It took me 3 runs in my Rustang to realize what felt like a slow shifting trans was actually me just barely touching the rev limiter.
Stay tuned, I'll post up my slip tomorrow night along with a corrected number for comparison. I'll see if I can get the truck weighed also.
Old 06-08-2012, 08:26 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
What are you guys getting for 0-60 times?
Old 06-08-2012, 08:42 AM
Racer5349's Avatar
Racer5349
The timing systems won't give times like that. The usual incrementals are:
-Reaction time
-60' time
-330' time
-660' time and mph (1/8 mile)
-1000' time (sometimes mph too)
-1320' time and mph
Here's the slip from my Mustang ;
Old 06-08-2012, 09:08 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I meant on the road, not at the strip
I wrote a small program that takes timestamps and road speed readings from my SCT X3 datalogger and spits out 0-60 times. Last time I checked my '01 V10, I was getting 9 seconds flat. But that was before the hedman headers and a few other little things that hurt performance.
Old 06-08-2012, 10:13 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Something I've definitely been wanting to do. The last time I tried, my tablet flew off my dash and landed on the back floor. No flat roads out here to test it on but I'll see if I can come up with something soon. I'll be using my Torque app with the OBD connection so it should be pretty accurate.
There's a thread goin' on in the 6.7 forum, Darren32's tuned 6.7 hit 6 sec's with the 0-60. Screenshot is in the "Burnout" thread.
Old 06-08-2012, 10:28 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
jeez. I wonder how many times it's going to do THAT before it explodes?
Old 06-08-2012, 12:42 PM
Strokt350d's Avatar
Strokt350d
My brother in law has a 6.4 liter. Used to have a stock tranny, with a 500hp race tune. The truck was beyond nuts. It would literally spin around if you floored it at low speeds.
He used to launch the truck to the floor with the brake on, like 50psi, in 4WD and he did that for years with no problems at all.
The 6.7 supposedly has a better tranny that the 6.4, right? I would guess so. Those tranny's can take a POUNDING......
Old 06-08-2012, 03:52 PM
2000silverbullet
Well, if it can stand up to me banging it into 2nd gear full throttle at ~5800 rpm while pulling 16,500 lbs uphill, that seems to be a pretty good indicator.
Old 06-09-2012, 06:25 AM
Strokt350d's Avatar
Strokt350d
You pulled 16,500 with your 6.2? Manual shifting up a hill @ 5800....
Tell me more!!!!
Old 06-09-2012, 06:43 AM
2000silverbullet
It's all in the Ohio meet thread: videos, times, and speed results:
https://www.ford-trucks.com/forums/1...nd-videos.html
Quick Reply: 1/4 mile performance
