Busted Leaf Spring
Busted Leaf Spring
I recently bought a '99 F-250 SD with a 6" Rough Country suspension lift. While looking over the truck once I got home I noticed the rear passenger side leaf spring is busted. It is a 6/1 leaf pack & as far as I can tell is the factory spring. The top 2 leaf's are broken & separated by about an 1/8 inch right in the middle. The previous owner tried patching the problem by welding the leaf's to one another to stop them from moving. My question is how bad is something like this gonna effect my ride & is it something I should fix immediately? I understand it isn't gonna ride like a Cadillac with a 6" lift & 40" tires but I am trying to get the smoothest ride I can. Thanks for any input!
get that death trap off the road!
ya man... or someone else who is beside you on the road when your axle hellicopters out from under your truck.
park it till its repaired... with NEW springs!
never, EVER ... try to weld a broken leaf spring.
cost of new springs - vs. - killing yourself or someone else
my .02
xtof
my .02
xtof
Springs are nothing to mess with. Get it fixed ASAP.
right now you have the factoryu spring with the lift kit's add a leaf to lift the rear of the truck. Youd be much better off buying a set of lifted rear springs for a six inch kit. One it will ride way better, second it wont axle rap nearly as bad, third you can get rid of them weak 13 year old springs that will break on the opposite side soon
Leaf Spring 4 IN. PROGRESSIVE RUBBER NEW Rear Ford PART | eBay
6" 99-07 Ford Super Duty F250/F350 4x4 Rear Leaf Springs | eBay
4" 99-04 Ford F250/F350 Super Duty Rough Country Rear Leaf Springs | eBay
New Skyjacker Leaf Spring Rear Ford F-250 Super Duty 2007 2006 2005 2004 FR94S | eBay
Ok so I got new springs, they will be here tomorrow. Now for my next question, & I apologize if this is a dumb one but I've never worked with suspension parts before. I was looking under the truck today & am curious exactly how the axle is located on the spring in the right spot. Is it fool proof & they will automatically line up square & in the right position or do I need to do a bunch of measuring & squaring & stuff like that to get the axle set on the new springs properly?
jimcar-9
10-31-2014 12:36 PM
octaneforce
05-04-2010 09:50 PM
