aftermarket rim question
06-05-2012, 07:49 PM
Quote:
Originally Posted by
Tuxedo Scorpion
Where are you wanting the tires to be, in relation to the fenders? Sticking out? How far?
06-05-2012, 07:50 PM
on
The black would be nice on your truck. Personally I would get the all chrome ones, but like all the chrome on the truck.
06-05-2012, 07:52 PM
what do you guys think about this
06-05-2012, 07:53 PM
First, you need to decide what size tire. Then what offset. Then finish.
Not every wheel you like will come in the size/offset that you want.
kmonty2
i want the the best of both worlds, some black, some silver.
06-05-2012, 07:55 PM
Andrew010
35x12.5x20
20x9
25 offset
06-05-2012, 08:02 PM
Tuxedo Scorpion
35x12.5x20
20x9
25 offset
You do realize that the tire will be tucked inside the fender with that offset??
06-05-2012, 08:07 PM
Andrew010
No i didnt realize. I get so confused with offset positive vs negative. I guess i want 0 offset then
06-05-2012, 08:16 PM
20x9 with zero offset will stick out about 3/4" ish. Front will be a bit more.
With a 4" lift and aggressive tires, I think you should have an aggressive offset as well. 20x9 with 0 offset would be the min, 20x9 with -12 would work too and stick out about 1.25".
06-05-2012, 08:17 PM
on
Depends on how far you want them to stick out the fenders. Tire size will also make up a bit of that
06-05-2012, 08:22 PM
Andrew010
1.25" would be perfect for me. 2" max id say
06-05-2012, 08:24 PM
on
What size of lift are you planning on going with?
06-05-2012, 08:25 PM
06-05-2012, 08:26 PM
on
Sounds good. That much sticking out of the fender would look nice with that much of a lift.
06-05-2012, 08:34 PM
All these wheel configuration programs online, would be awesome if they had a lift configurator with tire size and offset options. Argh
