6.7 Power Loss Towing
#31
In hind site I should have kept it! It was over GVWR when towing this trailer. I don't think that was a big issue but My Outback 280 is made to carry a quad or something in the front. I don't have anything at this time and with the lower tongue weight it swayed badly with the F150. It set off the built in sway control on the ford. That sucked this thing was moving a lot! I could have used about 400lbs of ballast but that would have put more weight on the truck.
#32
I guess I will take this truck out and see where I hit the limiter with no trailer.
#33
I was told they are limited at 97 mph and seems right on my truck.
As for towing up hills, I tow my 36 foot, 10,500 lb 5th wheel up Mount Eagle, in Tennessee between Nashville and Chattanooga. It's 5-% one way and I think 5-7 % the other way. I started at the bottom running 55mph and floored it, boost maxed out at 23 or 24 lbs I think (mid way on the gauge), and it climbed and pulled like a scalded ape! I was running almost 80 mph and still climbing when I hit the brakes to make the turnback. Then at about 65 I floored it again and same thing, I was pushing 80 mph when I had to do the turn back again.
I did the same thing coming home the next week. It just happens I'm leaving this Wednesday going over the same mountain again, should do the same. The temps did rise to about 210 for engine and tranny though.
I would see if a dealer mechanic will take a ride with you because that doesn't sound right. I did have the waste gate solenoid valve replaced, not because of lack of performance but the weird noise after shutting it off. If the solenoid is failing maybe the boost is blowing out, possibly after the gauge reads it I don't know, but if it were like that then your engine would not be burning the fuel and spooling up the ponies.
#35
Something to try with you guys having the 400/800 and 6 speed. Why not go into manual mode in 3rd or 4th, pull to max rpm and shift into the next gear? My TSwill notussually shift up at max boost and ificould drop it a gear and then force a shift it would probably keep accelerating.
The thing is, I am thinking your filters for fuel are a potential issue possibly too. When you are pulling hard with boost maxed out, computer needs the fuel to be able to go with boost or you will get detonation and problems. So, the computer is possiblylimiting fuel or boost due to a sensor, could be fuel pressure, could be egt probe. I am just thinking out loud, but it would be cool to compare fuel at low pressure side, high presure rail and verify you don't have an issue.
I would also check y our air filter and filter minder and try and compare boost with others insinuations under load to see if you are getting all you can? 20 lbs sounds low to me but I don't have a new truck. On a hill like that mine will hit 29 easy, but then as I pull at that kind of grade it builds to 26 psi and that's when she starts to really pull hard, at this point injectors are dumping a lot of fuel and if there is a problem on the low or hi side, this is when you will see it IMO.
#37
#38
#39
#40
Shelby, I hooked up my 4k gooseneck trailer Monday night with 1000 gallons of WVO on it. So about 11500lbs, for a half hr drive, no real hills tho.
When I was cruising at 65 mph I stomped on it just to see how it would react. It dropped down a gear (or two?) and took off like I was going to leave the trailer behind. I couldn't imagine that it would have acted much different at all going up a mountain, but at least I think it would have tried to speed up.
I did notice one thing that was not good, but I think it was driver error. As I was getting onto the highway I was slowly speeding up and I gradually put the pedal all the way to the floor, the truck never down shifted and took a long time to get up to speed. The next time I was in that situation I let off the gas and then stepped on it quicker, it down shifted and speed up quick and I did not have to put the pedal to the floor.
Just my experience, hope some of this is useful.
#41
#42
#43
#44
Is there any specification describing your max boost and show it on the gauge. Depending on how you read it, mabe map to an edge and see what it says. I can't help but think some are not getting the full 400/800 like the OP with his issue. I do have an older truck, but I think I know what he is talking about in a hill pull where you think she should walk away with it and crest the hill accelerating. The other thing is where is the torque max in the rpm band, and shift manual mode to find that and see if it helps. The OP trailer is light. Only other thing is trailer brakes dragging? Just trying to help.
#45
Did you take pics of your EOT readings? I've had great luck with dealers and difficult to reproduce symptoms with taking videos. I even got a free extended maintenance package from Ford because of that. Be sure to call Ford customer care and escalate your concern!
