AOD/speedometer help
Old Jun 4, 2012 | 09:31 PM
fatfenders56's Avatar
fatfenders56
I would appreciate any info that any of you can give me on applications or years that AOD transmissions used a cable rather that a reluctor to drive the speedometer. I have a VDO electronic speedometer that needs to attach to an actual cable drive at the trans end. Thanks in advance
Old Jun 4, 2012 | 09:52 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Not exactly what you asked for but, may help.
Speedo Cable To AOD Swap - Vintage Mustang Forums
Old Jun 5, 2012 | 07:24 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Take a look at a 64-66 Mustang cable. Whatever fits the C4 and FMX also fit an AOD. I was going with an 85 Ford AOD but ended up with an FMX. The same cable fits either one...
Old Jun 5, 2012 | 09:19 AM
CharlieLed's Avatar
CharlieLed
I am confused...why would an "electronic" speedometer require a "cable" drive? Is it really a "cable" or is it the style of speedometer drive coupling on the trans tailshaft? I just happened to have an AOD in the back of my truck so here are a few pics of the speedo connection...this trans is out of an 89 Mustang.
Old Jun 5, 2012 | 12:58 PM
seanmconroy's Avatar
seanmconroy
That looks like an encoder type basically that gives pulses back to the speedo and more pulses it receives the faster speedo will show ect. That is an electric sender unit. Try 1986 crown Vic wagon for a mechanical type. Cos that is what I took mine from
Old Jun 5, 2012 | 01:42 PM
mytbtruck's Avatar
mytbtruck
Autometer has a GPS unit that eliminates the rotating speed sensor in the transmission. The price is pretty steep and most of us don't wan to pay that much but sometimes we have to do things we wish we did not have to. Just thought I would mention it .
Old Jun 5, 2012 | 06:09 PM
fatfenders56
Thank you all for the quick responses. A trip to visit a Ford Master Tech today verified that C4s and AODs use the same size drive units. I am using a VDO electronic speedometer which has it's own encoded sensor that hooks to the trans. The VDO encoded sensor attaches to the trans with a threaded collar that is the same size/thread as the screw on connection for a FOMOCO (C4) mechanical cable. I am in the process of obtaining a C4 unit right now. I'll post some pics when I get when I get all the pieces. I thought the Crown Vic/Lincoln unit would work but the Ford explosion book shows the sender and the cable one piece all the way to the speedometer. Thanks again to everyone and to Jeff and Nicolle for the link to the Mustang forum
Old Jun 5, 2012 | 08:30 PM
Jeff and Nicolle
My friends just call me Jeff Nicolle is just along for the ride!(My Boss)
Old Jun 6, 2012 | 09:43 AM
fatfenders56
Thanks Jeff
Old Jun 6, 2012 | 04:33 PM
topmoo's Avatar
topmoo
Speed hut has a GPS speedo too that is affordable. You just have to put a small magnetic antenna on the dash for it to read.
dotcentral
Aug 18, 2014 11:24 AM
cstapleton
16
Jun 27, 2011 11:32 PM
blue57
Jul 16, 2007 09:13 AM
mtflat
Jul 9, 2002 08:42 AM
