Brakes: Upgrade on the way
Hello all, I just ordered the following:
Product Image
And:
Product Image
Looking forward to seeing how the slotted rotors and new pads perform. Hopefully next weekend I will have some pics and install notes.
Product Image
And:
Product Image
While slotted rotors have visual appeal, thet will not change your braking ability. The slotted and drilled rotors in the past allowed the pads to out gas. The pads in use today do not have the gassing issue the older pads had. As far as rotor warping is concerned there was thread on that earlier that dispelled this myth.
I too look forward to seeing how an improvement over factory will perform.
Not cryo rotors.
Virtually same price as quality OEM replacement so I figured why not?
I tow a lot and have never been thrilled with stopping power, especially from 40-0 mph.
My brakes are not quite worn out, 3mm in front after a little over 100K.
The pads seem to be the more oggresive move in making improvement over stock. I compromised longevity over the max grip type pads. Should still be better.
Not cryo rotors.
EBC brake pads do not need a bed in procedure. Just install...and drive for about 400 miles with easy brake pedal. They bed themselves with a special compound on the face of the pad.
Actually...works really...really well.
The Powerslot rotors that I installed on my SD...I have not been overly impressed. Not so much the product...but the customer support. IMHO...the customer support was terrible! Or should I say...Nonexistent! YUCK! etc...and so on. Hope they have improved over the years...
biz
biz
biz
400 easy miles.... you are kidding right ??
You should be able to bed in a set of pads within a few miles, depending on traffic. Just gotta drive it like you stole it.
From EBC website : Brake Pad bedding is very important for brake pad wear and brake pad performance.
Most fun I've had bedding at set of brake pads and new rotors was on Venice Blvd in a Ferrari 360. Ahhh, the good ole days.
Rotors should be remove and replace.
Why would a person need to contact customer service ??
Did they have fitment issues, warping ... what should a person watch for on these ??
_
If you run your hand along the surface of a slotted rotor you should be able to feel the almost sharp abrupt edge of the slots.
A cross drilled rotor will have the edges of the holes chamfered.
_
_
_
Yes...serious. It's with the instructions on the pads. No harsh stops...unless in emergency situations. Plus...here is a cool vid to help the point.
<iframe width="420" height="315" src="http://www.youtube.com/embed/DsQX8UAAlLg" frameborder="0" allowfullscreen></iframe>
Yeah...the Powerslot rear rotors were warped out of the box. After weeks of trying to get them replaced with company...I decided to just get them turned...and be done with it. I know...brand new out of the box...and having them turned...not the best...but at least I was back on the road.
biz
I thought about it but have never done it so I figured I would just go with the normal hardware first. You are certainly correct, braided lines are supposed to be a significant upgrade to any brake system.
