Air filter full of oil
thanks Buzz44 it is time for my oil change I will go ahead and just put 6 quart and see if that solves the problem, but I see what you mean 7 quart in a 6 quart system and not upgrading to a bigger pan could be the problem,the only reason I did that is because I knowest that when I was driving on the highway my oil pressure would drop and if I got off the highway as I was slowing down the pressure would go up, so I thought all the oil was on top and none at the pan that's why I added the extra quart but anyways Ill try 6 in my next oil change and see what happens thanks again you are all great
Thanks once again for the quick response guys. HIO SILVER thanks for the image that is the way my system is hooked up the shroud is in both valve covers,now I did put two 5/16 dia brass rods, one on each side of oil passage to the valve train to reduce oil flow to the top and also so the pan would have enough oil for the pump to keep lubricating the system, now I see how you divided the oil 4 on top, 1 in the mains and 1 in the pan. I knowrest that to thats why I added the reducers I made to keep more oil in the pan, I went ahead and added one more quart making it 7 total. do you think this extra is bean added to the top causing the problem I'm having? Thanks again in advance.
If you take off the flute that the rockers go on, there is 4 or 5 bolts that hold it down one of them is thiner that is where oil is feed to the valve train,if you look inside where the threads are your going to see and oil passage that gos in an angle that's where I put the piece of rod I made it to stick out just enough that I can grab it with some pliers but short enough that it does not interfere with the bolt you might have to shave one side to adjust the flow of oil,install the rod put everything back together and start the truck and see if you like how it lubes the the rockers if god you are don if not take all apart and shave the rod until you are happy with the flow of oil, no mes because oil dos not squirt it just flows enough to lubricate that's all hopefully you understand what I just explained
OK, I just had visions of those in the drainbacks...forgive my pessimism. I am enjoying one of the benefits of being a pessimist right now, as we are also pleased when we are wrong about something....
This does not help your problem though. The overfill is the next suspect and you are on to that.
Our '66 wagon 390 lived happily with 5 quarts, but that was a car pan, and afaik, the trucks take 6.
on
Are you saying that you are adding 7 qrts of oil to a 6quart system? Thats what it sounds like in the above statement you made. Fe take 5 quarts plus one for a new filter when you do a complete oil change. You may have excess oil causing a restiction in you pcv system thus causing backpressure from the crankcase to blow oil out of the breather intake tube into the air cleaner. Unless you added a larger oilpan you should not need more than 6 quarts.
orich
Blowby and alot of it is my guess. I can't see how else you would get that much oil into the filter housing. Like said before a good way to get an idea is plug off oil fill cap (If vented) and pcv vent so your engine is sealed (I just use my hand) hold it for a few seconds and see how much pressure is created. There shouldn't be any if everything is perfect with ring seal to cylinder. But there usually is and a small amount can be delt with by the pcv system. To much on the other hand blows alot of air through the only way out... The pcv. All this air is obviously going to carry oil with it....
Ok I'm going to throw some questions out there. First if you look at the diagram. The PCV is between the drivers side valve cover and the carb.(not air cleaner) then the hose from the air cleaner to the pass. valve cover(creating a loop). If you have pcv's on both sides it creates a flow problems and builds gas preassure in the crank case. Next if you pull the oil cap off while it is running does it have alot of air/steam comming out ? It will have a little air comming out but if there is blow by you might even have oil getting blown out.(I know it is a rebuild but some times the oil rings grt their slots too close together). If that all checks out then I woul go to checking under the valve covers.
on
Did this just start doing this or has it been an on going problem since the rebuilt??
Also do you have stock valve cover or aftermarket. Reason I ask some aftermarket one's don't have the PCV bathel around the pcv valve letting old to be sucked up into it and end up in the air filter.. 5/16 BRASS rods as oil reducers GEEZ seems like a hoking way to do it when you could of just use a Holley carb jet of any size you want to choose to reduce flow..Oh well we all have a way of doing things..orich
#28
Ford Super Duty Man
07-15-2009 09:22 AM
CeeJay
04-13-2005 09:58 AM
