Heater always hot; vacuum help
I have been trying to trouble shoot my wife's '99 Exp and things are getting worse as I go. It has had rough idle and missing on long hills. I was getting codes for LEAN Bank #1 and Bank #2 so I have been looking for a vacuum leak. During that process, I replaced the PCV valve. The aftermarket PCV valve was slightly shorter than the Ford part which caused it to pop out when I was driving. Then I really had a vacuum leak. The heater began to only put out hot air no matter what temperature I selected. I got the PCV valve reseated and temp control returned. Later, the PCV valve came out again and I again lost temperature control. I finally moved the heater hoses around enough that the PCV valve stays in place, but now the heater is staying hot no matter what temperature or which vents I select. Does anyone have a detailed diagram/description of the vacuum lines as they pertain to the heater system? Thanks.
Thanks, I already checked that connection. In fact, I have already had to replace that elbow...not a fun job.
loquito
05-09-2014 09:01 AM
fordx94
12-23-2004 09:55 PM
