ignition coil b on 1996 ranger 2.3l
Old 04-24-2012, 07:37 PM
96rangerkid's Avatar
96rangerkid
96rangerkid is offline
Hey i was wondering if anybody could anwser this question: my engine has 2 ignition coils, and b went bad, but i have no idea which one is b. Help?
Old 04-25-2012, 08:56 PM
LastStarfighter's Avatar
LastStarfighter
LastStarfighter is offline
I would guess that Ignition b would be the one with the wires running to the intake side of the engine.
just a guess.
Old 04-25-2012, 09:13 PM
96rangerkid
i hope your right. i just had one replaced and got worried it was defective. thank you.
Old 04-26-2012, 05:50 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
just a guess.
my guess for B is also the driver-side(intake)
that is the side that ignites on the exhaust stroke......on cold starts it will not even fire...........if that was the one that got replaced the truck should have still started and ran.....
Old 05-03-2012, 07:48 PM
96rangerkid
it wasnt, but then i switched and cleared the code it came back. i found that the ground was also slightly oxidized. i cleaned it and im waitin to see what it does. thank you tho
Old 05-03-2012, 08:13 PM
LastStarfighter
If that fixes it throw some dialectic grease on there. It will keep it nice.
Old 05-07-2012, 07:21 AM
96rangerkid
i have done that and my code came back. im starting to think its resistor that is right before my ground. i'm gonna try doing a voltage drop test and see what happens
Old 06-22-2012, 03:00 PM
samw57's Avatar
samw57
samw57 is offline
my truck spudders on acceleration in 3rd & 4th gear. I've replaced all the plugs and wires but not the coil packs. Starts up just fine and doesn't act up while idling. I was going to check the ground and connections to make sure they are corroded. any other suggestions would be great help
Old 06-23-2012, 12:09 AM
michigan66's Avatar
michigan66
michigan66 is offline
Take the old coil pack to an auto parts store and have them bench test it before you spend more money on parts. Also, you indicated that you have a trouble code. Post it here and we can be of more help to you.
Old 06-23-2012, 12:56 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Fires on the exhaust stroke. Um that doesn't even make sense. Both coils packs are waste spark, so they BOTH fire on both the intake and exhaust stroke.
It is true though that only one coil pack fires during startup.
oneminizut
151
08-26-2013 08:26 PM
73ford
03-09-2002 08:01 PM
Nathan
03-28-2000 08:32 PM
Quick Reply: ignition coil b on 1996 ranger 2.3l
