Mass air conversion and now no cruise (e4od)
Old 05-30-2012, 07:41 PM
D-RockJD's Avatar
D-RockJD
D-RockJD is offline
Question Mass air conversion and now no cruise (e4od)
New to the threads here but looking for insight on solving this problem. Put in dunne rite performance mass air conversion kit with baumann tranny controller. Drove the bronco down the road before the conversion to reasure everything in working order as it was. Since doing the conversion i have lost my cruise control features. Spoke with the guys at baumann and have confirmed with me the eec IV and cruise module are seperate from one another. connectors are all good,fuses good, module was working as far as i knew until after conversion. checked vacuum and theres no leaks hoses are solid. any light on this situation would be appreciated.
Old 05-30-2012, 11:13 PM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
Maybe something got knocked out of place doing the conversion. Have you checked all wiring under the hood? Isn't there a connection on the master cylinder for the brakes? Maybe something there
Old 05-31-2012, 07:15 AM
D-RockJD's Avatar
D-RockJD
D-RockJD is offline
ill check it out, second look can never hurt.
Old 05-31-2012, 11:14 AM
hivoltj's Avatar
hivoltj
hivoltj is offline
What year bronco, and vacuum or electric cruise? I'm betting something is unplugged.
Old 05-31-2012, 12:35 PM
D-RockJD's Avatar
D-RockJD
D-RockJD is offline
It is vacuum, ill check it out today sometime and let you folks know
Old 05-31-2012, 02:22 PM
D-RockJD's Avatar
D-RockJD
D-RockJD is offline
any possibility of or heard of the vacuum device failing before? ive been over it a dozen times now all connectors are pushed in solid no frayed wires or cut vacuum lines
Old 05-31-2012, 02:31 PM
GuitarJesus
Well if its anything like the directional vents in an A/C system, one small leak and it won't work. Could be a pain to find
Old 05-31-2012, 06:18 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
I'm not sure of you can with these truck or not but on my buddy's old jeep we gave little sprays of I believe it was ether in areas and when the truck revved up a bit then we narrowed down the area for the leak an sprayed in that area to get closer till we found it.
Not so sure of its a good idea or would work tho...
Old 05-31-2012, 06:42 PM
GuitarJesus
Just like with gas line. Soap. It will bubble
Old 05-31-2012, 07:00 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
The hard part here is getting inside the vacuum hose so you can see the bubbles!!!!
tech 101
1999 to 2016 Super Duty
07-08-2015 09:40 PM
D-RockJD
1978 - 1996 Big Bronco
05-31-2012 11:09 AM
david00f150
09-18-2006 12:34 AM
mustangman65_79
13
05-25-2004 09:01 AM
lightninglowe
03-18-2003 01:25 PM
Quick Reply: Mass air conversion and now no cruise (e4od)
