Off Road Lights INSTALL with PICS
Old 05-27-2012, 02:12 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
Hey tux I thought you were going with triple lights up front?
I used two KC daylighters on my bullbar and they are plenty bright also.
Looks like a good clean install and with solder joints and shrink wrap you will never have to worry about a bad or intermittent connection either!!
Old 05-27-2012, 02:33 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
Tuxedo Scorpion is offline
3rd light is on the bench. Had a hardware mounting issue, waiting for replacement part ...
Old 06-02-2012, 09:33 PM
Tuxedo Scorpion
UPDATE: part came in, installed no.3 to include the necessary wiring
decided the proper way would be to integrate the new wiring into the existing routing / sheathing, which required removal of previous install, then modify to accomodate the addition. also decided to tap splice the ground into the existing to eliminate excess wires, thus one ground, two hots run to firewall.
then braided the 3 wires and shrink tubed them (adhesive lined)
then anti chafe sleeve with more adhesive lined shrink tubing to finish
then started routing back toward the pass thru wires, finished up the connections, zip tied and tested
Old 06-02-2012, 10:36 PM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 6,929 Likes on 2,178 Posts
That looks like another job well done. Looks great too!
teds74ford
139
10-08-2017 12:46 PM
shanes66charger
Ford Truck Parts for Sale
04-04-2016 01:20 PM
AzPatMan
01-22-2013 03:23 PM
teds74ford
12-20-2012 11:32 PM
Sunline Fan
12-20-2011 01:35 PM
Quick Reply: Off Road Lights INSTALL with PICS
