4R100 to ZF-6 swap
Here's how I change all the fluid: Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles. Many shops have a flush machine that connects into the cooler lines. As the trans pumps old fluid into the machine the fluid pressure pushes a piston that forces new fluid into the trans. The new fluid follows the same path at the same or slightly reduced pressure. It does NOT harm the transmission. Using flush chemicals MIGHT harm the transmission.
I don't know what a "purge" so to speak is.
Then you've seen different machines than I have. The ones I've seen remove the old fluid from the cooler line and replace it with new fluid. The new fluid follows the exact path that the fluid always follows, and at the same, or slightly reduced pressure. It can't push dirt and contamination anywhere that it isn't already stuck.
lvin4jc
09-27-2010 12:59 PM
1yamman350
08-22-2003 03:40 PM
pcman
08-20-2003 12:31 AM
