Trailer wiring issue
Hi i recently wired a 7 Blade socket in place of the factory 7 pin and it tests alright, but when i hook it up to two of our trailers no matter what function i use it turns rev lights on. I am stumped because the trailer lights work fine with our other vehicles. Any ideas?
Thank you for your time.
Double (triple) check your wiring here. https://www.ford-trucks.com/forums/5...g-diagram.html
Don't forget the ground wire from RV plug to the truck connection.
EDIT
I was wrong i had the revers wire and +12 volt mixed up, but more issues have arrisen
I have it figured out, while testing it the other day to get the rev lights to work i had the key on, well that caused the +12 volt power to be on and i mistoke that for the rev so thoes were swapped and i had troube because i had a diagram of the trailer side of the plug so that also messed me up.I also figured out that the fuse was blown causing the rev not to work. so hopefully that is all.
idsubgun
06-19-2013 08:07 PM
Hometown Pride
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-16-2007 08:02 PM
jake00
10-30-2006 08:45 PM
