Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
1954 F-100 (D)
Old 09-15-2018, 07:08 PM
54TexasF100's Avatar
54TexasF100
54TexasF100 is offline
New Delivery. Heidts Superride II.
  #137
Old 09-18-2018, 12:46 PM
54TexasF100
Unpacking to make sure I have all the right parts.
  #138
Old 09-18-2018, 01:00 PM
54TexasF100
Built an engine stand so I can run my engine once in a while during teardown.
  #139
Old 09-18-2018, 01:06 PM
54TexasF100
Well, I removed the Aerostar IFS. It served me well for many years. I also got the Thunderbird IRS removed and cleaned up ready for redesigned installation once the Heidts is in place.
  #140
Old 09-18-2018, 01:17 PM
54TexasF100
Installing the boxing plates. I need to determine if I want to box the entire frame. More thought to be had...
I started by measuring the 19 3/4". I then clamped it in place and tig tac welded. I finished the top tig in spurts of 1-2 inch lengths alternating frame rails. I will leave the top showing the tig welding but smoothed out the bottom.
  #141
Old 09-22-2018, 08:19 AM
54TexasF100
Crossmember installation started.
  #142
Old 09-22-2018, 08:26 AM
54TexasF100
A few more pictures.
  #143
Old 10-01-2018, 03:33 PM
54TexasF100
Putting the pieces together as it were but enough of the small talk because no one really cares...pictures time!
  #144
Old 10-01-2018, 04:53 PM
fordman75's Avatar
fordman75
fordman75 is offline
It's looking good!
  #145
Old 10-13-2018, 08:02 PM
54TexasF100
Boxed in the rear frame rails.
  #146
Old 10-13-2018, 08:59 PM
fordman75's Avatar
fordman75
It's looking good.
  #147
Old 11-11-2018, 03:55 PM
54TexasF100
Working that rear.
  #148
Old 12-07-2018, 07:53 PM
54TexasF100
c'd the fame for upper a-arm Clarence.
  #149
Old 12-07-2018, 08:04 PM
54TexasF100
here she is with some guts
boughts some qa1 coilovers because i wanted something slicker than the original springs
just need the figure how to mount...currently temp installed in stock shock low-cal
  #150
Old 12-07-2018, 08:21 PM
54TexasF100
no matter where i positioned the engine while setting up where to weld the motor mounts, the stock oil pan fouled
enter the shinny canton oil pan that set me back 3 bills but was made for this setup. wow
Quick Reply: 1954 F-100 (D)
