Restoring headlights with Meguires one step restoration kit
The lights on my truck were really yellow and oxidized so i bought a meguires one step headlight renewal kit to try. It came with the buffer for a drill, a bottle of plastX and a rag for buffing. I tried it out and the lights look alot better but will it last? have you tried it? how long will it take before they are cloudy again?
I bought a bottle of a similar product from the dollar store in town here that you just put on a rag and wipe on the light covers. It was like 3 dollars for an 12 oz bottle of it, and it only takes like 1/4 oz to do a light. It works really good but they start to re-yellow again in about 6 months. Which isn't too bad I don't think. Meguires makes really good products so I would guess it will be just as good if not better than my 3 dollar bottle.
Better lights
My 90 f250 lights were dull and foggy in 2009 I WET sanded them with 1500 grit wet or dry sandpaper ... It took about 10 min. per side. Then washed them with lots of windex, then masked around them with blue tape. Cleaned the surfaces to be treated with lacquer thinner and a clean rag for each side. then sprayed with light-thin coats of clear lacquer (rattle can) until completely covered then let it dry completely. ... That lasted 2+ years then repeat as needed !!! Side note I run 9004 Sylvania Ultras with no problems Just my $.02 worth Dave
Here's an interesting read from another forum that I am on. It seems that they like the clear coat idea too.
How to restore plastic headlights
7.3 down
24
12-18-2013 01:18 PM
Saxon
12-21-2009 07:03 AM
